Vinyl Fence Posts Around Existing Metal Poles - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By ron45
Old 04-24-2019, 11:53 AM   #1
Rewards Points: 60
vinyl Fence posts around existing metal poles
Hi,
My property line wall already has metal poles for a chain link fence every 8ft, but the missus hates the idea of chain link and so we are going with vinyl fencing. See photo here:
https://photos.app.goo.gl/5izmSkwQMg445cUA7
What's the most reasonable way to install the fence posts?
Do I trim the metal poles down and slip the vinyl posts over them?
I've read that some people fill the vinyl post with concrete, but others say that expansion of the concrete would crack the vinyl posts.
Advice appreciated!
Regards,
Theodore2
Theodore2 is offline   Reply With Quote
Old 04-24-2019, 12:17 PM   #2
retired framer
Rewards Points: 20,276
Re: vinyl Fence posts around existing metal poles
I would drill holes in squares of plywood and figure a way to attach them to the post, they would hold the vinyl centred and stop them from turning. 3 each, top bottom and centre. Or even vinyl trim board.
Do not use flat bottom gables with scissor trusses.
Old 04-24-2019, 01:07 PM   #3
DoomsDave's Avatar
Rewards Points: 5,532
@Theodore2 , welcome!
Please put your location in your signature (city/county and state/province) as some advice can be location specific.
DoomsDave is offline   Reply With Quote
Old 04-24-2019, 01:58 PM   #4
Rewards Points: 60
Location is Fairfield, Connecticut
Old 04-25-2019, 07:55 AM   #5
Rewards Points: 4,406
https://www.youtube.com/watch?time_c...&v=Hf3-tKyp8Cg
Nealtw and HenryMac like this.
ron45 is offline   Reply With Quote
Old 04-26-2019, 02:28 PM   #6
Hammered Thumb
Rewards Points: 2,038
I've used the "U" brackets to attach wood fencing to old chain link poles. In a couple spots I have installed larger diameter poles (galv not vinyl) over the smaller ones (to get more height) and filled them in. I would guess some vinyl manuf's have some ready-made brackets like ron45's video shows. I would just be cognizant of the 8' span and the wall thickness of the vinyl to span without sag.
3onthetree is offline   Reply With Quote
Old 04-26-2019, 03:16 PM   #7
Rewards Points: 528
How about something like this? Depending on the size of your posts. You would have to get the 8' vinyl fencing that could be cut down to size.
https://www.therookpostmount.com/the-rook/
taylorjm is offline   Reply With Quote
Fence posts not plumb. Did contractor mess up? stags14 Building & Construction 23 04-29-2018 09:58 PM
Thoughts on this idea for fence posts. LarryJ-nova General DIY Discussions 8 04-22-2016 11:37 PM
Concrete w vinyl fence post. USCav Concrete, Stone & Masonry 8 03-21-2016 02:03 PM
? Regarding Building a Fence (Posts + Stain) PolishPete Carpentry 0 08-20-2013 01:03 PM
Metal Trim For Vinyl Flooring Against Bathtub Lynden Flooring 5 09-13-2012 10:00 PM
