Underground Sprinkler - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-29-2016, 08:52 AM   #1
Rewards Points: 58
Underground sprinkler
Wondering if anyone can help me with this. I've got a blue polyethylene pipe sticking out of the ground for my underground sprinklers. See the pic. We use to have a brass or plastic piece that would allow attachment to the garden hose What piece do I need so that I can attach the garden hose to this pipe?
saxsquad29 is offline   Reply With Quote
Old 05-29-2016, 09:41 AM   #2
Rewards Points: 58
Re: Underground sprinkler
So basically I need a fitting so I can connect this 1" poly pipe to standard male end of garden hose
Old 05-29-2016, 06:29 PM   #3
Rewards Points: 1,042
Here's what you need, get it at HD or Lowes.
http://store.rainbird.com/drip-low-v...ction-kit.html
Canarywood1 is offline   Reply With Quote
Old 05-29-2016, 07:14 PM   #4
Rewards Points: 58
This is actually for drip irrigation tubing. What I have is polyethylene tubing 1" in diameter that leads out to 3 underground sprinkler heads. I need a setup that connects the end of the 1" poly tube to a standard garden hose
Old 05-29-2016, 07:20 PM   #5
Rewards Points: 7,546
I don't see a spec for hose size on that, but it doesn't look like anywhere near 1".
Really, all OP needs is a 1" hose to 3/4 NPT female-swivel barb brass fitting. And probably a gear type hose clamp to secure the hose to the fitting.
Might have to make that up from a couple of pieces --- male hose barbs are more common. But should not have too much trouble finding a 3/4 NPT male to female adapter.
SPS-1 is online now   Reply With Quote
Old 05-29-2016, 08:25 PM   #6
Rewards Points: 58
I found a nylon hose barb 1" ID to 3/4" MIP today at HD, but it's leaking around the barb fitting even with tightening the heck out of hose clamp. Would a brass fitting be less likely to leak?
Old 05-29-2016, 08:36 PM   #7
The barb end should have been tight in the hose even before tightening the hose clamp. Your pipe must not be a true 1" ID. Brass might be better than plastic, but I would not count on it. Maybe try wrapping some black electrical tape around the barb before pushing it into the hose, then hose clamp.
Old 05-29-2016, 10:29 PM   #8
Rewards Points: 2,579
I have always been under the impression that PEX barb fittings are pretty fussy to install. You need a special crimp ring and a special tool for crimping it and then then you have to measure it with another tool to make sure that your special crimping tool is specially calibrated.
It's not like a rubber radiator hose where you can just tighten a hose clamp around it until it stops leaking.
mathmonger is online now   Reply With Quote
underground sprinkler blow out 4just1don Landscaping & Lawn Care 2 11-10-2014 09:46 AM
Locating underground lawn sprinkler pipes Thurman Electrical 8 06-30-2014 07:33 PM
Underground sprinkler system 4just1don Landscaping & Lawn Care 3 05-24-2014 11:49 AM
How to mend underground sprinkler electrical wire diyatx Electrical 1 02-28-2013 01:47 AM
locating underground sprinkler lines denemante Landscaping & Lawn Care 9 02-14-2012 09:24 AM
