Underground Gutter Drain Question - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-11-2015, 09:33 PM   #1
Rewards Points: 94
Hi, I am looking at a way to pipe away a proposed partial gutter system on a lot with severe grading/drainage issues. One contractor suggests running a gutter along the eves on the back of the roof into a 4” PVC pipe that would travel along the side yard picking up another short run of gutter from a valley along the way before finally taking the water to the street.
The problem is is that the curb is about a 12-15” rise from the house. He suggests that once the pipe starts at back of house, it will be sloped underground until just before it reaches the curb and then elbowed up vertically to the surface, terminating in a pop up emitter.
Looking at the measurements involved and considering a 1/4” minimum slope, the pipe would be almost 30” underground before going straight up. This seems to me to be less a drain than a bleed-off outlet relying more on rising water than gravity to get the water to the street. I would like to know if anyone has seen a system like this work effectively in heavy (2-4”/hour) rains. I don’t have the roof measurements handy, but it’s a lot of water involved -often coming down very fast- and I’m concerned that it would tend to back up before draining.
Thanks.
RedYucca is offline   Reply With Quote
Old 07-11-2015, 11:26 PM   #2
Rewards Points: 17,912
Sounds like a silly idea to me.
Water does not run up hill.
Pop ups will stop working at some point.
First choice is always to run the drain to day light.
No one knows where you are because there's no location in your profile so there may also be freezing issues.
concretemasonry (07-12-2015)
Old 07-13-2015, 09:15 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Ayuh,..... Any water dumped in the top, will exit the bottom, so long as the outlet is lower than the inlet,....
Think of it as a fast movin' semi-drywell,....
Old 07-15-2015, 03:16 PM   #4
Rewards Points: 94
Thanks for your responses. I am in Central Texas (flash flood alley). The house is situated in a three-sided bowl making it impossible to daylight to surface.
Joecaption: I appreciate your point about the failure potential of pop-up emitters. I am also concerned with how much the pop-up would neck down the 4” pipe.
Bondo: I see what you mean that it would work in theory. The contractor said that it would work just like a P-Trap... of course a P-trap “knows” how much flow to expect. Have you seen a system like this work fast enough in very heavy downpours to keep from backing up?
Old 07-15-2015, 07:58 PM   #5
Bondo's Avatar
Ayuh,.... It'll flow as much water as will pass through the size of pipe in a given time,....
If ya don't think 4" can flow enough, go to 6",.....
Mini split drain line question? charliefreak100 HVAC 40 06-13-2016 10:39 AM
Dehumidifier question - basement drain vs sump pump? cjaustin81 General DIY Discussions 35 11-01-2014 11:24 AM
Interior French Drain Question ccg4444 Building & Construction 10 08-19-2014 10:50 AM
Kitchen drain making basement washer drain back up... mjd616 Plumbing 6 03-15-2014 11:33 AM
Basic Question on plumbing (planning to unclog bathroom sink drain) babyfishmouth Plumbing 1 07-31-2011 12:14 AM
