Underground Drainage Pipe Material - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree8Likes
Old 01-25-2018, 05:04 PM   #1
Rewards Points: 1,100
Underground Drainage Pipe material
What's the latest pipe type for this application? I know the standard is basic corrugated, and then there's PVC.
But, I spoke to a landscape professional today and he told me PVC was bad b/c it gets brittle over time and is not UV resistant for pvc above ground.
He said his company uses some sort of High Density Poly for underground pipe that is smooth in the interior to allow it to be snaked without damage. What is this new product?
handy man88 is offline   Reply With Quote
Old 01-25-2018, 06:15 PM   #2
Rewards Points: 17,914
Re: Underground Drainage Pipe material
If it's an "underground" drain how is the UV rays going to effect it?
PVC is smooth in the bore and has been used for septic systems for a very long time with no issues.
Bondo and mark sr like this.
Old 01-25-2018, 07:47 PM   #3
That's the question I asked, but the pvc that's above ground that's exposed to the sunlight or the pvc that's below ground but in a high sunlight exposure area including direct exposure to temperature extremes if not laid below the frost line can cause it to become brittle, according to the rep.
Old 01-25-2018, 07:56 PM   #4
retired framer
Rewards Points: 20,766
Have a look at vinyl siding. If after 20 years the pipe sticking out of the ground gets brittle. It will just be the foot or so out in the sun shine.
Sounds like you are up against a high pressure sales person. If is in not more expensive go for it.
Old 01-26-2018, 06:13 AM   #5
Iím just trying to learn more about this new high density poly option. Not trying to bash pvc.
Old 01-26-2018, 06:31 AM   #6
JUSTA MEMBER
Rewards Points: 4,098
I think that they are "blowin sunshine" up your skirt.
Meaning that they are just lying to make a sale.
I personally know that pvc piping can be above ground in direct sunlight for more than 30 years, and still be good.
Get a name for this wonder pipe, and report back so we have an inkling as to what it is.
ED
Nealtw likes this.
de-nagorg is online now   Reply With Quote
Old 01-26-2018, 06:38 AM   #7
retired framer
http://pcisupply.com/en/high-density...-variations.sn
HDPE
Flexible, durable, lightweight. Ideal for general purpose ducting of communication, data and coax cable uses. Resistant to decomposition, oxidation and other elemental conditions. Available in various sizes (0.75” – 4.0”) and colors.
PVC Pipe
Strong, lightweight and resistant to inclement weather, sun exposure, fire and chemicals. Ideal for both indoor and outdoor installations.
de-nagorg likes this.
The Following User Says Thank You to Nealtw For This Useful Post:
handy man88 (01-26-2018)
Old 01-26-2018, 06:48 AM   #8
Guapo
Rewards Points: 11,950
88, it's much easier to work with corrugated pipe when installing it underground due to it's flexibility.
Bondo likes this.
Guap0_ is offline   Reply With Quote
Old 01-26-2018, 07:40 AM   #9
ED
My guess is that it's a version of this:
https://sc01.alicdn.com/kf/HTB14OP7J...pg_350x350.jpg
The Following User Says Thank You to handy man88 For This Useful Post:
de-nagorg (01-26-2018)
Old 01-26-2018, 07:41 AM   #10
Yes, but if there's a blockage, you can't put a snake down corrugated which could tear it up.
Old 01-26-2018, 07:52 AM   #11
retired framer
The cheap corrugated flexible pipe with or with out pick up holes is the HDPE
https://www.homedepot.com/p/4-in-x-1...0010/100212428
Pvc is smooth with or with out pick up holes but it is stiff so fittings are required.
https://www.homedepot.com/p/4-in-x-1...-100191022-_-N
Bondo likes this.
Old 01-26-2018, 08:07 AM   #12
Guapo
88, there is far more chance of a blockage with a 2" PVC than there is w/ 4" corrugated.
Old 01-26-2018, 08:23 AM   #13
Well yeah. I planned to be putting in 4" pvc vice 4" corrugated...until the first company I met with talked about rigid HD poly pipe.
I'm scheduled to meet with two more companies today and see what they say, but I'm avoiding corrugated for new applications.
Nealtw likes this.
Old 01-26-2018, 09:15 AM   #14
Guapo
I think that you are going to have a hard time with the pitch if you use PVC. Corrugated pipe can roll like a roller coaster & still work.
Old 01-26-2018, 07:19 PM   #15
Rewards Points: 4,434
I can't seem to find the reason why you are putting this pipe in the ground for.?
ron45 is offline   Reply With Quote
Patching/sealing old concrete drainage pipe? Norwest Concrete, Stone & Masonry 10 08-12-2015 04:39 AM
Washing machine drainage issue Centex2011 Plumbing 6 10-08-2014 03:45 PM
Underground downspout drainage: Water standing in my brand new drainage pipes Airgibson Landscaping & Lawn Care 15 06-06-2012 07:41 AM
The IPGC Drainage Pipe agster97 Landscaping & Lawn Care 0 07-09-2009 12:05 AM
Insulate Underground Sump Pump Pipe Basic_Homeowner Landscaping & Lawn Care 1 07-23-2008 08:32 PM
