Underground Drainage Pipe -- Glue? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-28-2015, 08:46 AM   #1
tiger1964's Avatar
Rewards Points: 96
Underground drainage pipe -- glue?
Replacing old black flex-corrugated drainage pipe, starting to silt up, with 4" white rigid dripped pipe (and landscape-fabric sleeves to prevent silting up again). Not a fun job. Anyway, is this stuff intended to be press-fit or glued? I replumbed the whole house, w/PVC or CPVC where appropriate, so I'm familiar with gluing the joints; however, is it the "correct" installation?
tiger1964 is offline   Reply With Quote
Old 09-28-2015, 10:21 AM   #2
47_47's Avatar
Rewards Points: 320
Right or wrong I prime and glue landscape drainage pipe.
Instead of the sock, I've had good success lining the trench with filter fabric. Put in a few inches of a drainage stone, lay pipe, add more stone to cover pipe, fold fabric closed, then back fill trench.
47_47 is offline   Reply With Quote
The Following User Says Thank You to 47_47 For This Useful Post:
concretemasonry (09-28-2015)
Old 09-29-2015, 01:02 PM   #3
Rewards Points: 4,414
If you live in an area where ground movement is a concern, I wouldn't glue the joints, the bells will crack.
ron45 is offline   Reply With Quote
Old 09-30-2015, 07:29 AM   #4
tiger1964's Avatar
Rewards Points: 96
Those are both good responses. It seems I have a judgment call to make.
Which kind of pipe...What size? maddog1 Plumbing 25 08-24-2015 06:13 PM
Patching/sealing old concrete drainage pipe? Norwest Concrete, Stone & Masonry 10 08-12-2015 04:39 AM
Heavy-duty roots in ground drainage pipe proofer Plumbing 11 08-06-2008 04:42 PM
Underground orangeburgh pipe leading to storm sewer is blocked somewhere flashme18 Plumbing 10 07-21-2008 11:48 PM
glue for drain pipe? tikicarver Landscaping & Lawn Care 8 02-07-2008 09:03 AM
