Trimmer Line Issues - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-24-2016, 03:58 PM   #1
Rewards Points: 168
Trimmer Line issues
I have a Homelite. It is auto/tap feed.
When installing line, I am supposedto thread the line thru the head so equal amounts on each side, and then turn dial on head to draw tag ends in closer.
I can do this fine, however, the line continually goes back inside the head.
And yes, I am turning the dial on the head the correct direction, as it is the only direction in the the dial turns.
giddyap is offline   Reply With Quote
Old 09-24-2016, 07:11 PM   #2
Rewards Points: 2,190
Re: Trimmer Line issues
Sorry, I don't know anything about the homelite trimmer. I have a kawasaki and a troy built. I have two buttons at the bottom of the head that I can push in that enables me to advance the line in either direction, keeping the line from going back into the head. Don't know about homelite.
Google your owners manual if you don't have one, check out utube videos or call the manufacture and ask them. The information you seek should be there, or it's possible somethings broken causing your issue. Just a thought.
Hope you get it figured out soon.
jmon is offline   Reply With Quote
Washing Machine Water Supply Line Issues Disconnecting to Reset? North_Woods Plumbing 5 08-28-2015 06:26 AM
Service pit for main water supply and sewer line sonnaps Plumbing 3 07-23-2015 10:54 AM
Fixed Line Trimmer Heads semajhsurb Landscaping & Lawn Care 2 05-19-2013 09:02 AM
Old metal waste line to PVC issues LTParis Plumbing 21 04-01-2013 04:19 PM
sewer line Master Brian Plumbing 3 05-25-2009 12:53 AM
