Trim Pine Tree - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By mark sr
  • 1 Post By Msradell
Old 05-06-2019, 12:44 AM   #1
Rewards Points: 687
Trim pine tree
I am not sure what type of pine tree I have, but would like to cut the limbs near the bottom, and somehow make it thinner and shorter if possible.
greentrees is offline   Reply With Quote
Old 05-06-2019, 04:49 AM   #2
retired painter
Rewards Points: 2,070
Re: Trim pine tree
Any idea why some of the branches died? They rarely come back so it would be best to cut them. While it's usually considered best to trim trees in the fall I've never seen any issues with trimming pine in any season.
mark sr is online now   Reply With Quote
Old 05-06-2019, 10:18 AM   #3
Hammered Thumb
Rewards Points: 1,096
Re: Trim pine tree
I'd consider removing it altogether. Cutting the top of trees is not proper - it interferes with their continued growth vitality. It also looks as if the main trunk was cut before and now there are just two offshoots. Those are weaker, off balance, and at some point will probably break with a good wind.
If its the size and open canopy you want to be different, there's a different tree to match your desires.
With your username I woulda thought you'd be telling us what to do
3onthetree is offline   Reply With Quote
Old 05-06-2019, 10:19 AM   #4
DoomsDave's Avatar
Rewards Points: 2,620
Re: Trim pine tree
@greentrees , looks like your pine has an infestation of some kind of bad bug, which caused some of the branches to die back. I'd cut those off, and maybe burn them if you can.
Be careful about topping a pine too much. You can nip the top a bit, and it will branch, but cut down too far, and it will stop growing from that lead.
Maybe give us a more detailed idea of the problem you're trying to solve?
DoomsDave is online now   Reply With Quote
Old 05-06-2019, 10:30 AM   #5
retired painter
Re: Trim pine tree
I missed the making it shorter part - IMO it is almost always a bad idea to top a tree.
Bondo likes this.
Old 05-06-2019, 12:40 PM   #6
DoomsDave's Avatar
Re: Trim pine tree
Mature pines, for sure. Younger trees and dicots are a bit better to do that with, though one has to be careful.
Old 05-06-2019, 01:53 PM   #7
Rewards Points: 687
Re: Trim pine tree
Any idea what type of pine tree this is? I was trying to see if there were any cutting techniques for this specific pine tree. Sounds like topping or severe trimming would be an issue. I think there is some issues with shade that might have killed part of the tree.
This tree was part of the house purchase, so trying to figure out what to do with it. I don't really like it since it seems too large for that area. A scrub would be better. In the photo you can see that the tree sits on a ridge. I was thinking the roots might help keep that ridge intact, or maybe the boulders are really doing the job. If I remove the tree I was worried that it might compromise the driveway in some way.
I would really like to cut it down to 6 feet, but maybe better just to remove it and replace it with something easier to manage.
note: about 90% of the tree is still green, so greentrees might still apply. Though I can't take credit for any of the trees around my house.
Old 05-06-2019, 09:26 PM   #8
Msradell's Avatar
Rewards Points: 708
Re: Trim pine tree
If anything it would be better for your drive might and that ridge to get rid of the tree. The roots have to be exerting pressure against a stone retaining wall and could eventually make it tumble.
mark sr likes this.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 05-07-2019, 10:10 AM   #9
Rewards Points: 512
Re: Trim pine tree
I agree it is best to remove entirely. Trimming in warm season could attract beetles. Cover the stump with something thick and goopy.
Cedrus is offline   Reply With Quote
Old 05-07-2019, 06:18 PM   #10
Rewards Points: 687
Re: Trim pine tree
I wasn't thinking that the tree might affect the stones, but you are probably right. I am not sure what the house looked like originally, but assume the stones were there to begin with. Cutting down the tree and replacing with a small scrub would be nice. Any suggestion on an evergreen tree or decorative tree that might look nice?
I had a larger pine cut down in the front of the house. I was a few feet from the foundation. I drilled a few holes in the trunk and put some epsom salt in the holes. This hopefully will dry out the stump. Not sure if there is any issue with beetles.
Guide to cut down a tree Michae888 Flooring 2 09-01-2017 09:46 AM
Help Me Save a Tree! l008com Landscaping & Lawn Care 11 06-30-2017 10:35 PM
How to trim this oak tree? elmonorojo Landscaping & Lawn Care 7 04-30-2017 09:27 AM
Door & Window Trim / Casing Overhaul - Craftsman Style lohryx5 Remodeling 7 07-11-2013 07:52 AM
