Toro Engine Timing After Gasket Replacemnet - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-16-2010, 03:49 PM   #1
toro engine timing after gasket replacemnet
replaced my toro 22 recycler gasket, noticed the gears had shifted upon removal of oil pan, do i need to be concerned about timing?
bwiese is offline   Reply With Quote
Old 11-16-2010, 04:26 PM   #2
Rewards Points: 248
It should not be a problem if you mean that the crankshaft and camshaft simply turned while the crankcase was open, but if the camshaft slippled out, and the gears disengaged from each other, then yes, you need to check that they are properly aligned. You will need to look at the shop manual, to make sure that you have everything in the right place, but beyond that, it should be a simple matter of reopening the crankcase, aligning the marks on the crankshaft and camshaft, and reasembling it.
Toro Recycler mower w/ Tecumseh 6.5 engine - starts and immediately dies Pickngrin Landscaping & Lawn Care 40 07-14-2012 07:43 PM
Snowblower engine problem TKE174NH General DIY Discussions 2 12-15-2009 09:18 AM
Help with toro self propelled 5.5 b & s engine model 20464 justeend79 Landscaping & Lawn Care 6 06-03-2009 08:59 AM
