Tips On Fast Setting Concrete For Posts - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By chandler48
  • 1 Post By Msradell
  • 2 Post By Canarywood1
Old 01-04-2018, 06:26 PM   #1
Rewards Points: 148
Tips on Fast Setting Concrete for posts
Ive always done the mix and pour for all my concrete work but I find its a huge pain especially when I work on my own. Im looking for tips on using the mix in hole fast setting concrete, the instruction say poor in hole and then poor in water, I find it hard to believe the water will saturate good, is it better to poor water in first then add concrete. Looking for some tips on people with experience using the fast setting stuff.
Oddjober is offline   Reply With Quote
Old 01-04-2018, 06:47 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 4,308
Re: Tips on Fast Setting Concrete for posts
If you are doing only a few, or a single, like a mail box post, you may find the following product helpful. Sets up quick and holds like steel once it expands. https://www.homedepot.com/p/Sika-33-...3503/205671519
Msradell likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 01-04-2018, 10:18 PM   #3
Msradell's Avatar
Rewards Points: 824
That stuff is certainly worthwhile the best way to go as long as you don't have a lot of posts to do. Sets very quickly and holds very well. The only disadvantage is cost but if you're only doing a few posts it's not a big deal.
chandler48 likes this.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 01-05-2018, 11:25 AM   #4
Rewards Points: 1,042
Yes if it seems to be to good to be true, it usually is, mixing a bag the usual way is how i'd go, just for peace of mind.
Canarywood1 is offline   Reply With Quote
Old 01-05-2018, 12:12 PM   #5
Guapo
Rewards Points: 11,950
$12 each & sets in 3 minutes? I'd have to be rich & fast to use that stuff! At best, I would use it for chain link posts. You don't need any mix for wood posts. & you would need a truck load for PVC posts.
Guap0_ is offline   Reply With Quote
Old 01-05-2018, 01:18 PM   #6
CodeMatters's Avatar
Rewards Points: 6,640
I couldn't force myself to follow the instructions. Might have wasted time
by mixing it but that's how I'm wired.
CodeMatters is online now   Reply With Quote
Old 01-05-2018, 01:26 PM   #7
retired framer
Rewards Points: 20,660
I tried that adding water after the product was in the hole. Yeah right fast setting but you have to wait for the water to do what. I see other people have figured out just how much water to have in the hole mix in the bag and touch up the water if needed.
Old 01-05-2018, 01:33 PM   #8
jlhaslip's Avatar
Rewards Points: 708
Some people don't add water to the hole.
Drop in the post, throw in half a bag of readimix and then backfill it.
The ground water will dampen the readimix and over time the concrete will be hardened.
Not recommended for corner or gate posts.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 01-05-2018, 02:03 PM   #9
retired framer
We have one outfit that back fills with dirt and sprinkles some gray on top. 1 bag 30 posts.
Old 01-05-2018, 02:55 PM   #10
Geeze, they should be sued for malpractice.
Fix'n it and Nealtw like this.
Tips on self-leveling concrete spaceman spif Flooring 23 04-10-2016 02:56 PM
Concrete w vinyl fence post. USCav Concrete, Stone & Masonry 8 03-21-2016 02:03 PM
Any tips for creating some cool effects when staining concrete? ahreno Concrete, Stone & Masonry 11 03-07-2016 05:59 PM
Tips for laminate over imperfect concrete mom929 Flooring 3 08-20-2013 10:40 PM
stone veneer formula tom1st Landscaping & Lawn Care 1 07-08-2006 04:48 PM
