Testing Soil? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-04-2015, 03:00 PM   #1
JOATMON
ddawg16's Avatar
Rewards Points: 9,320
Testing Soil?
I think I have a soil problem in my back yard. Last year I put down Marthon sod and in short order, about half of it died.
This summer I put down St Augustine sod...looked great for 3 weeks then it started to look sick...not just in spots, but all over.
A little background....the back yard was trashed during construction. I've used to to rinse out buckets of paint and drywall mud.....not to mention all the other things that get rinsed off during construction.
I had hoped our winter rains would have gotten rid of any stuff leached in the soil.
I'm wording if I significantly changed the PH.
I picked up one of those electronic PH testers....I don't see any difference in readings no mater what I do.
My next thought is to pick up a soil test kit.
Any good ways to figure out what is causing my problems?
Old 08-04-2015, 07:19 PM   #2
Rewards Points: 202
I'm a few miles up the road from you, Michigan, but just wondering, Sir, did you cultivate the soil before laying the sod? I would, definitely, in this case. You probably have some high concentrations of lime wherever you rinsed out your buckets, and I saw and enjoyed a lot of your pictures, so know that you had a lot of foot traffic, at least in some areas, so the soil may be too compacted for the sod to take root? I believe that you are on the right track with soil sample analysis, but make sure that you get good results by taking them from areas other than where you were cleaning out buckets and so on. Here anyway, the county extension service will take them, as will several local nurseries, and while some of the information has been more than my little mind can handle, they always include a layman's version as well. Whenever I have collected samples, it has been from something like a couple of inches down, as that is where the roots will be, and from three or four separate spots mixed together, to avoid localized "contamination", whatever that may be.
Old 08-05-2015, 11:07 PM   #3
PE Mechanical Engineer
Thunder Chicken's Avatar
Rewards Points: 862
I'd say send off samples of your soil to a local agricultural extension for proper testing. Many agricultural schools offer this service, generally only costs $20 or so, and they'll send you a detailed report that tells you how to correct the condition for turfgrass. They are usually very happy to answer questions too. Google 'agricultural extension soil test' and you'll find a bunch of schools that do this.
Gypsum will definitely drop the pH of the soil, but that may not be the issue. Gypsum is used as a soil amendment in areas with acid soils.
Also, I see that you are in southern CA - how is the drought out there? If you haven't been able (or allowed) to water the sod regularly, you might be out of luck trying to get sod to stick.
Thunder Chicken is offline   Reply With Quote
Old 08-06-2015, 12:09 AM   #4
Rewards Points: 4,406
Speaking of drought, how hard is the ground.?
ron45 is offline   Reply With Quote
Old 08-06-2015, 12:38 AM   #5
JOATMON
ddawg16's Avatar
My back yard is fine. Between the 2 story garage and huge avocado tree....it only gets about 5 hours of full sun a day.
Old 08-06-2015, 09:57 AM   #6
Rewards Points: 862
How much water does it get? Sod needs regular watering for about a month before it gets established. And are you sure that it is actually dying? Water stressed grass will generally go dormant (turn yellow) until it gets sufficient water.
watering hole for scrubs. safe? greentrees Landscaping & Lawn Care 6 05-30-2014 10:34 AM
Dying grass needs help greentrees Landscaping & Lawn Care 19 05-18-2014 03:49 PM
Soil testing and lawn rejuvination jjrbus Landscaping & Lawn Care 5 04-19-2013 08:01 AM
Small Yard, Tree Roots....? JayNYOne Landscaping & Lawn Care 6 11-13-2011 06:30 PM
Backflow device testing - possible scam? ScottR Plumbing 9 06-14-2009 10:55 AM
