Tapping Into Main For Irrigation - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-01-2017, 04:21 PM   #1
Rewards Points: 164
Tapping into main for irrigation
Should this be in plumbing? I'll start here.
Need to tap into the main for irrigation. When I dug up where I wanted to do this, about 2 feet from the meter I found this. Perhaps an old repair? I was going to post and ask what type of tee to use but expected just some 3/4" pipe. What's the preferred way to add a tee here. Looks to be not copper as I had hoped.
I will use sch 40 1" to the shut off and then PCB.
jAndrewH is offline   Reply With Quote
Old 04-07-2017, 10:09 AM   #2
Rewards Points: 122
Re: Tapping into main for irrigation
looks like some type of transition coupling with a reducer. What's the material type of the pipe? looks like galvanized steel? To answer your question, you can cut out a section of pipe and drop in a tee with slip on transition couplings on both side of the tee.
Joeycarnuba is offline   Reply With Quote
Old 04-07-2017, 11:51 AM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 638
That is a Dresser coupling (Google it) for galvy pipe. You could replace it with a Dresser tee.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 04-07-2017, 04:35 PM   #4
Rewards Points: 164
Thank you. I decided not to tap into there for fear of breaking that galvanized pipe. I went from the crawl space where the main enters the house. This also gives me a better location for the PVB.
Tapping into main cast iron line using Fernco tripower Plumbing 9 11-26-2013 07:48 PM
Main Breaker in a Main Lug panel? fulmar2 Electrical 17 01-30-2013 11:16 AM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 09:40 AM
main lug vs main breaker for sub panel diyll Electrical 1 01-17-2008 08:18 PM
