Surface Drainage Around House - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-23-2014, 10:15 PM   #1
Hi Everyone,
I just joined and looking forward to posting in this community.
I have a drainage issue at a house I recently bought and wanted to get feedback and advice on what to do. (Please let me know if this is the correct forum to post the question in).
The house was originally built in the 1700s into the side of a hill with natural ledge. This probably helped provide a natural foundation at the time. A slab foundation is currently installed. Various renovations have been done on the house. At some point tiered stone retaining walls were installed in the back to provide a larger yard area at the top as well as a terraced garden.
The problem I am having is moisture at the back of the house (the first floor is below ground level). I don't know if the back wall was ever properly sealed or if the slab was sealed or if there is drainage around the base of the slab. It would cost too much to excavate the backside of the house since the whole hill would need to be held back during the work so I'm going to rule that out.
All I can control is surface drainage. The roofs all have covered gutters leading to downspouts that are piped to the street in solid 4" PVC so that solves the roof. What I'm trying to figure out is how to direct the runoff from surface water at the back.
I'm assuming any sort of traditional drain with crush rock against the back would be a bad idea since its inviting the water in and I cannot get deep enough to have the drainage go below the slab. What I'm thinking about is the following two-pronged approach:
1. putting french drains in back of each of the retaining walls to divert water away before it reaches the house.
2. Installing a watertight surface channel drain slopping from the center away on each side and resealing the concrete to create a watertight channel.
Overall the moisture issue isn't too bad unless it rains so I'm thinking most of this is coming from the top down and not from below the foundation. So if I can solve the surface water issue and get a powerful dehumidifier for the first floor I should be better off. Ideally I could get the whole back wall clear and see what is there but that isn't realistic given the ledge and retaining wall issues.
Here is a link to the pdf I made detailing the issue visually: (edit can't post links yet).
Any suggestions would be much appreciated. Please let me know higher budget suggestions too. I can always try and bandaid it now and solve it permanently down the road.
Thanks!
luchazard is offline   Reply With Quote
Old 07-23-2014, 10:20 PM   #2
Link to visual: http://docdroid.net/f51w
Link to drain: http://images.lowes.com/product/conv...63076409lg.jpg
Old 07-23-2014, 10:51 PM   #3
Here's a picture of the space between the second floor and the first retaining wall. As you can see standing water has been an issue. You can also see the bedrock protruding from far side. I think the bedrock actually helps reduce moisture coming up from the ground. This might be why the primary issue is surface water and not ground water / hydrostatic pressure so much.
Blow toward fence or house in tight location ric in alberta HVAC 16 07-03-2012 06:27 PM
Drainage problem, water under the house Rockobuster Landscaping & Lawn Care 2 01-04-2010 04:52 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
Drainage drainage and more drainage... Badfish740 Landscaping & Lawn Care 7 09-15-2008 11:47 AM
