Sump Pump Install This Weekend... - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 08-25-2015, 09:26 AM   #1
Rewards Points: 68
Sump pump install this weekend...
Well, I have started multiple threads to try and figure out the best way to solve my issue. Summer is about over and all other plans have fallen through. My last resort is to install a sump pump. Ive ordered a 1/3hp Liberty pump rated around 2000 GPH. It will be installed in a 18"x22" basin. I plan to run 2 French drains and connect 3 downspouts together that run to the basin.
I don't have any slope to work with on one of the planned French drains so I plan on having the pipe input into the basin pretty low. Will this cause an issue? I was going to shoot for having the input of this French drain about level with the switch on the sump pump; approx. 8-10" from the bottom of the basin.
I am finally starting this project this weekend.
Thanks for the help!
jabrock1 is offline   Reply With Quote
Old 08-25-2015, 10:27 AM   #2
Rewards Points: 5,348
You failed to mention the reason you're doing this.
What you're doing is unclear. Is this sump pump and basin inside or out? How are you connecting interior French drains to an exterior leader system?
Ron
B. Franklin 1759
Old 08-25-2015, 10:48 AM   #3
Rewards Points: 68
Sorry I wasn't clear. The sump will be outside. French drains will be in the problems areas of my yard. Yard stay wet from around October to April. Only drying out in the summer months or long periods of no rain in the cooler months. my side yard is lower than the street and the water has no where to go. I am surrounded by neighbors fences on 3 sides.
Pic below was after a massive rain.
Old 09-06-2015, 08:27 AM   #4
Rewards Points: 2,800
Tdeleted ...............................
Stick to your lawn watering schedule until it really starts to pour. After the storm you have only the same number of rest days you always had and then you need to start watering again.
Old 09-06-2015, 08:29 AM   #5
The perforated French Drain pipes do not need much slope. An eighth of an inch per foot will work.
The portion of the basin above where the drain pipes pour in does not count as storage volume. You will need to make the basin deeper still. I suggest having at least 4 cubic feet (about 30 gallons) worth of empty space not filled with rocks below where the drain pipes enter.
A basin the size of the plastic sump pump basin liners they sell in the stores is much too small for a system used to handle gutter water or yard water.
Still better would be regrading the land to have some slope plus swales to some lowest point, preferably near the front of the property, where you have the basin with a perforated exposed lid and no perforated underground pipes.
Old 09-06-2015, 09:52 AM   #6
Civil Engineer
Rewards Points: 5,246
Where are you pumping the water to?
Old 09-06-2015, 11:11 AM   #7
Concrete & Masonry
Rewards Points: 344
Any chance there's storm sewer on your street? If so, it could be a much more reliable, effective cure, although the upfront cost will likely be more............
jomama45 is offline   Reply With Quote
Old 09-06-2015, 03:48 PM   #8
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Ayuh,.... Check his earlier posts for pictures, 'n details,....
Old 09-08-2015, 02:45 PM   #9
Rewards Points: 14
A drainage solution...
As a landscape drainage contractor, I can tell you the chamber systems work well for us and can be adapted to almost an situation.
C_Niel is offline   Reply With Quote
Sump Pump Questions henlij Plumbing 22 03-16-2015 10:00 PM
Help with Sump Pump Basin lancestorm Plumbing 5 12-28-2011 08:05 AM
Sump Pump Electrical Problem loftezy Electrical 5 09-06-2009 06:14 PM
Sump pump drainage question famdog Plumbing 1 01-05-2009 01:42 PM
Foundation drain and sump pump slatergrl Plumbing 3 02-10-2008 09:36 AM
