Suggestions For Organic Lawn Fertilizer? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By lenaitch
  • 1 Post By Raymondo17
Old 03-29-2017, 12:53 PM   #1
Rewards Points: 8
Suggestions for organic lawn fertilizer?
Does anyone have suggestions for organic lawn fertilizers and pesticides that actually work? We recently moved to a home that backs up to a large pond. We have St. Augustine grass but it needs to be fertilized as the weeds are taking over. Also have grubs and ants. I've always used non-organic in the past, so I'm new to this since we now have a pond with lots of wildlife and fish to protect. We want to maintain a nice lawn, but not to the detriment of the pond. Any advice would be much appreciated.
MichelleH is offline   Reply With Quote
Old 03-29-2017, 01:34 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: Suggestions for organic lawn fertilizer?
Begin with a mulching lawn mower. Aerate regularly. Sponsor some dew worms and start a compost pile.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 03-29-2017, 06:37 PM   #3
Rewards Points: 1,042
Your state agricultural center will have an extension service, or a state university will have one also, they can give you the guide lines for your area, potassium and phosphorus are the usual no no's.
Canarywood1 is offline   Reply With Quote
Old 03-29-2017, 07:06 PM   #4
Rewards Points: 4,226
I use a lot of coffee grounds, & eggshells, probably because I have them & some manure. I'm not sure about an organic source of potassium but potassium is a natural thing. Depends on your definition of organic, I guess. Overseeding with grass seed helps with the weeds. I'm not a fan of pesticides, herbicides, but then I'm not a farmer.
Maybe you could get an inexpensive soil test kit fr. a garden store & find out what you need. Soil tends to be alkaline here, washed out. Look up the ingredients in most fertilizers and it will show Nitrogen, Phosphorus & Potash. Forgive me if you know this.
I just noticed that you said the weeds are growing so you need fertilizer? Fertilizer makes weeds grow. Maybe you could clarify?
Nitrogen from manure can hurt your pond if you have fish etc., in it, as can the other chemicals in fertilizer. Everything breaks down to chemicals; it's a delicate balance
Nik333 is offline   Reply With Quote
Old 03-29-2017, 07:30 PM   #5
Usually Confused
lenaitch's Avatar
Rewards Points: 2,160
Well, for the fertilizer part anyway . . .
For the health of the pond, you need to manage your nutrient load no matter how it is derived. The suggests of getting advice from organizations such as agricultural, water management, conservation authorities, etc. is valid. A lot will depend on the amount of water exchange the pond has. They may also suggest some filter plantings such as cattails. I wish I had a pond - it was always something on my home shopping wish list but always fell off.
Nik333 likes this.
lenaitch is offline   Reply With Quote
Old 04-22-2017, 03:55 PM   #6
Rewards Points: 14
I'll follow up the photo of the horse with my suggestions for organic lawn fertilizer, but my suggestions refer to what goes into a horse, not what comes out.
Twice a year I feed my lawn like a horse: I give it soybean meal in the spring, alfalfa pellets in the fall, both of which I pick up at a local feed store, usually for less than $20 for a 50 lb. bag. Apply at 10-20 pounds per 1000 square feet. This feeds the microbes in the soil, which in turn, feed the lawn. I also use a mulching mower and mow at the highest setting that will provide a manicured look. The result is that I have the best looking lawn in the neighborhood.
Weeds, I usually manually pull them as I spot them. Dandelions are the main culprit in my lawn, which are relatively easy to maintain if you don't let them get a foothold. Oxalis is more difficult, but Bayer makes a product for broad-leafed weeds called Natria Lawn Weed Killer. It's derived from iron and is reportedly more environmentally friendly than most weed killers. That might be worth checking out. Vinegar is also a good organic weed killer, but it's not selective and will kill just about anything you spray it on, including your lawn.
Best o' luck with your lawn.
-Ray
Nik333 likes this.
Raymondo17 is offline   Reply With Quote
Old 04-22-2017, 04:38 PM   #7
That's really interesting. Turns out Natria is HEDTA. I'll be looking for that. Thanks.
Old 04-24-2017, 03:37 AM   #8
Rewards Points: 18
Not sure if this is in Texas, but popular in Colorado is Richlawn Turf Food - It's organic 'based' - so not sure if 100% organic (I think it is - you can check out their website). It's pellets from dehydrated poultry waste. Website says made for western U.S. They have some other products so you might want to check em out. I've used it many times and personally think it's great (greens up lawn as good as any non organic fertilizer)
Joe222 is offline   Reply With Quote
Old 04-25-2017, 11:32 AM   #9
RetiredSoldier's Avatar
Rewards Points: 29
I'd recommend checking out The Lawn Care Nut, on YouTube. He lives in the Tampa area and has lots of great advice for St Augustine grass. I use his highly recommended Milorganite fertilizer. It is an organic slow release fertilizer.
RetiredSoldier is offline   Reply With Quote
Old 04-25-2017, 01:21 PM   #10
Rewards Points: 266
I use Milorganite as a fertilizer and highly recommend it. Even if you apply too much, it won't burn the lawn.
http://www.milorganite.com
Marky82 is offline   Reply With Quote
Tags
fertilizer , organic , pond , st. augustine
Push lawn sweeper vs Lawn Mower rjordan392 Tractors & Mowers 2 11-25-2014 08:55 AM
Need help with front lawn greentrees Landscaping & Lawn Care 8 10-28-2014 09:35 PM
I treated my lawn with fertilizer and weed and weed and feed. now have yellow and brown stripes all over my yard jimmysiw Landscaping & Lawn Care 4 05-11-2013 05:20 PM
Why is my lawn NEON green? JL-KA Landscaping & Lawn Care 11 04-18-2013 02:37 PM
Please help with my ridiculous front lawn slope billyh Landscaping & Lawn Care 14 05-20-2012 07:46 PM
