Steps On Top Of HPB? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Bondo
  • 1 Post By Bondo
Old 08-28-2017, 10:03 AM   #1
Rewards Points: 2
Steps on top of HPB?
Does anyone know if I can build steps using pre-cast concrete (ie unilock) retaining wall blocks on top of HPB? I need to build about 5 steps to reach my door. I have some HPB down already and it seems to move quite a bit under the one or two "test blocks" I've laid down. Should i dig it out and put down 3/4 crush and sand instead?
Thanks.
FrankB416 is offline   Reply With Quote
Old 08-28-2017, 10:26 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Re: Steps on top of HPB?
Ayuh,..... What the 'ell is HPB,..??
Yes, 3/4"- minus will support 'bout any weight ya wanta put on it after compacted,....
Nealtw likes this.
Bondo is online now   Reply With Quote
Old 08-28-2017, 10:30 AM   #3
Rewards Points: 2
Lol! HPB (High Performance Beddibg) is 1/4" clear angular gravel.
Old 08-28-2017, 12:11 PM   #4
Bondo's Avatar
Ayuh,.... Sounds like washed pea-stones to me,....
If so,.... Move most of it outa yer way, 'n use crusher-run,...
Msradell likes this.
Need to repair newly poured concrete steps. mimoose Concrete, Stone & Masonry 10 10-18-2015 06:34 PM
plans for wooden back steps LMHmedchem Building & Construction 5 06-21-2015 03:33 PM
Basement Steps Branden Building & Construction 13 12-07-2012 07:14 PM
Exterior Wood Steps with Fieldstone Risers Leck Building & Construction 1 06-29-2010 08:32 PM
Re-staining inside steps saggdevil Painting 10 09-20-2009 06:40 PM
