Sprinkler Zone 3 Only Works Manually With Another Zone On - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-17-2018, 10:41 AM   #1
Sprinkler Zone 3 only works manually with another zone on
I have an 8 zone Hunter Pro C system that is several years old. This year Zone 3 stopped working when enabled through the controller, and does not work even if I manually enagage the solenoid. There is no water flowing at all when I remove the top of the valve box.
If I enable Zone 2 or Zone 1, which is further down the water line, then Zone 3 will work if manually engaged.
Replacing the solenoid and top of valve box did not help at all. I also verified the solenoid is getting power, not that it really matters for manual engagement.
Does anyone have an idea what I can try next?
joshbarber82 is offline   Reply With Quote
Old 06-17-2018, 10:57 AM   #2
Rewards Points: 2,186
Re: Sprinkler Zone 3 only works manually with another zone on
Welcome to the forums josh.
Possibly loose, or corroded wire somewhere causing the issue. I've seen bees and mud daubers cause problems. Check all wire connections. Just a suggestion.
jmon is offline   Reply With Quote
Old 06-17-2018, 02:09 PM   #3
Rewards Points: 7,496
What model of valves do you have? Zones 1,2,3 valves are on the same manifold?
SPS-1 is online now   Reply With Quote
Old 06-17-2018, 07:40 PM   #4
Rewards Points: 188
Do you have a master valve set up on the controller? That would explain why zone 3 has water when zone 1/2 are on.
Dan
djlandkpl is online now   Reply With Quote
Boiler heating zone not working properly ssevern HVAC 5 12-19-2009 06:05 PM
Adding new zone makapacs HVAC 0 11-26-2009 12:35 PM
Sprinkler control wiring re-connect (diagram) ScottR Plumbing 4 06-25-2009 08:51 PM
need some help sorting out my new heating zone please wombosi Plumbing 3 04-23-2009 04:54 PM
help with third heat zone i just put in... wombosi HVAC 6 04-21-2009 12:02 PM
