Sprinkler And Water Pressure Question. - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-21-2016, 03:36 PM   #1
Rewards Points: 76
sprinkler and water pressure question.
hello i am trying to run two sprinklers for my lawn. i cant get any pressure to run them both at the same time. is there anyway to get more pressure to run two sprinklers?
Sent from my SM-G900V using Tapatalk
charles3526 is offline   Reply With Quote
Old 07-21-2016, 05:34 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Re: sprinkler and water pressure question.
Ayuh,.... Buy a booster pump,....
Old 07-22-2016, 08:55 PM   #3
Usually Confused
lenaitch's Avatar
Rewards Points: 2,176
You need to consider both pressure and volume (flow rate). Your water supply (municipal or well) and the plumbing in your house can only deliver so much water volume to any given point. That's primarily why in-ground sprinkler systems often have zones. Two sprinklers are bleeding off your water supply twice as fast as one.
lenaitch is online now   Reply With Quote
Change water pressure regulator and repipe by main water shutoff daluu Plumbing 10 02-01-2012 01:02 AM
Home's Pressure valvue and sprinkler steve0617 Landscaping & Lawn Care 2 01-04-2011 01:37 PM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 05:23 PM
Any sprinkler contractors? Fluid dynamics engineers? Help determine water pressure jordansrt Landscaping & Lawn Care 3 07-31-2009 08:29 PM
City water pressure and volume question Jeekinz Plumbing 2 07-31-2007 12:18 PM
