Sprinkler Valves Leaking - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-02-2015, 11:58 AM   #1
Rewards Points: 2
I water most of my 2.5 acres using irrigation water from gravity fed water tanks. I use a water pump to pump the water from the tanks into the delivery system. I have a pump controller relay working with the sprinkler control timers to turn the pump on and off. The problem is that once the pump is off, there is not enough pressure in the line to let the sprinkler valves shut off completely. The seep and continue to leak. I understand that a bit of pressure is needed to get the valves to fully close. Is the best way to do that with a pressure tank? Can I just use the pressure tank to maintain a little pressure in the system and still use the pump relay to turn the pump on and off? I water for a few hours each day, so would a small tank be enough to maintain pressure in the distribution line?
Penryn Pal is offline   Reply With Quote
Tags
irrigation system , sprinkler valves leaking
Location of shut off valves, per IRC dave11 Plumbing 10 12-08-2014 05:40 PM
Selecting Sprinkler Wire ericksjr3 Landscaping & Lawn Care 2 07-27-2014 07:08 PM
One sprinkler leaking cprao Landscaping & Lawn Care 4 06-30-2011 09:38 PM
Stop valves in bathroom while drywalling StevePax Plumbing 11 01-17-2010 05:52 PM
shutoff valves all leaking hohadcr Plumbing 1 08-01-2009 06:38 AM
