Sprinkler Valve Leaking - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-17-2017, 09:03 PM   #1
Rewards Points: 14
Sprinkler valve leaking
Not sure if I should post this in here or plumbing. Anyway, today I went to do my spring startup. Turned on the main water valve to the sprinklers then turned on each sprinkler zone valve. When I did that three out of the seven valves started leaking. I was trying to google to see what could be the problem. Would changing the sprinkler diaphragm in it stop the leak? It's not leaking from the pipe just inside the valve. I'm going to try to clean it before i buy one since I read that could be an issue also. Any suggestions. Thanks!
pisano772 is offline   Reply With Quote
Old 04-18-2017, 06:32 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,650
Re: Sprinkler valve leaking
You should be able to find rebuild kits that include all the parts and pieces.
That valve looks serviceable in this case and it is likely O-Ring from the center of that solenoid if it is leaking from the center of that body.
Old 04-27-2017, 04:11 PM   #3
Rewards Points: 122
[QUOTEWould changing the sprinkler diaphragm in it stop the leak? It's not leaking from the pipe just inside the valve. Any suggestions. Thanks![/QUOTE]
It depends on where it's leaking from. If it's dry on top of the valve but wet on the bottom then is probably the diaphragm seal. But if it's wet on top then it's usually a bad seal, either at the solenoid or the bleed screw.
Joeycarnuba is offline   Reply With Quote
Plumbing Help - Valve Leaking at Stem MACooke General DIY Discussions 6 11-29-2016 08:08 PM
Hard to reach leaking gate valve mj12 Plumbing 2 03-16-2013 07:51 PM
Leaking ball valve in a gas line jshansen32 Plumbing 17 07-13-2012 09:58 AM
Seal for a leaking hot water heater safety valve topspinken General DIY Discussions 9 10-14-2009 03:51 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
