Sprinkler Valve Leak? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-06-2012, 11:09 AM   #1
Sprinkler valve leak?
Hello,
I recently had a sprinkler system installed in my backyard along with new sod.
I've noticed that the area where the valves are located looks wet. Granted that since it is new sod, my contractor leaves the sprinkler on for ten minutes or so, and could be that the water from the sprinklers is hitting the area.
My concern is if there is a leak that I should be worried about (especially since they are located next to the foundation.) Please see the picture.
Thank you.
jdelmund is offline   Reply With Quote
Old 05-06-2012, 07:14 PM   #2
Rewards Points: 1,042
Originally Posted by jdelmund View Post
Hello,
Thank you.
Have you tried running your sprinklers on manual to see if a valve is leaking??
Canarywood1 is offline   Reply With Quote
Mixer Valve Leak willie1617 Plumbing 2 04-10-2012 08:32 PM
Toilet leak continues after replacing parts Oldern Plumbing 0 03-29-2012 10:15 AM
Need some info on this valve -- got a small leak strad Plumbing 3 01-05-2011 08:45 AM
Need Help wiring 24VAC Sprinkler System fazlis85 Electrical 7 10-26-2009 08:27 PM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 08:19 AM
