Sprinkler System Problems - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-14-2010, 02:56 PM   #1
sprinkler system problems
I have a Hummingbird sprinkler system and I have 2 watering zones coming on at the same time. any suggestions?
gwsalado is offline   Reply With Quote
Old 07-14-2010, 03:44 PM   #2
Whats the problem? No enough water coming out of the sprinklers when both zones are on? Can you set the zones to come on at different times?
The Engineer is offline   Reply With Quote
Old 07-14-2010, 03:53 PM   #3
The zones are set to come on at different times. Zone 2 and zone 5 are the ones that are coming on at the same time. Water is coming on, but where I live (in the country) I don't have the water pressure to run 2 zones at the same time.
Old 07-15-2010, 11:43 AM   #4
Rewards Points: 5,348
Sounds like a wiring problem. If the common is coming into contact with both these zones, they will come on together. Check the valve box to see if the wires are separated and have their covering insulation intact. If that's okay, check the wire run from the control box to the valve box for staples that penetrate the wiring. Also check inside the control box for cuts in the outer sheathing or crimps where the wire enters the box.
Ron
Old 07-16-2010, 08:24 AM   #5
I'll check it out. Thanks
Old 07-16-2010, 06:38 PM   #6
Don't know it all, yet!
I agree with Ron. Sounds like some wires crossed together in there. Have you tried running each zone manually? Results?
If it's worth doing, it's worth doing right. If you wouldn't put your name on it, it ain't done right!
downunder is offline   Reply With Quote
Old 07-19-2010, 08:36 AM   #7
I checked it out Friday night, and it was a couple of wires crossed.
Thanks.
home fire sprinkler system boxofdaylite Remodeling 6 09-10-2009 01:11 AM
Installing a New Central Air System vdu HVAC 7 09-01-2009 04:45 PM
Problems with New System Boomersooner HVAC 6 09-16-2008 08:40 PM
Hot Water Heating System in older house GrannyAnnie HVAC 2 08-31-2008 05:50 AM
Drive Point Well for Sprinkler System? tigerbalm2424 General DIY Discussions 4 05-20-2007 12:38 PM
