Sprinkler System - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By Msradell
  • 1 Post By BIG Johnson
  • 1 Post By Edw
Old 06-13-2017, 08:02 AM   #1
Edw
Rewards Points: 38
Sprinkler System
Hello Folks. I have a two zone Rain Bird Sprinkler System. While charging zone number one, the Anti-Syphon Valve began leaking a lot of water. Does rotating the top of the Solenoid valve have anything to do with this water leakage? Thanks in advance.
Edw is offline   Reply With Quote
Old 06-14-2017, 10:46 PM   #2
Msradell's Avatar
Rewards Points: 818
Re: Sprinkler System
Rotating the top of the solenoid shouldn't have any effect on water leakage. It's totally outside of the wetted parts of the valve assembly.
Edw likes this.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 06-16-2017, 10:27 PM   #3
Edw
Rewards Points: 38
Thank you Msradell for the reply. Do you have any other thoughts as to why the Anti-Syphon Valve would be leaking water? Thanks again.
Old 06-17-2017, 10:09 PM   #4
Msradell's Avatar
Rewards Points: 818
My only guess would be that a seal inside of the valve is leaking. On the way to find out for sure is disassemble it and look at all of the gaskets and seals. I don't know how big yours is but it might be easier and certainly quicker to just replace it. Unless it's a large one they are not very expensive.
Edw likes this.
Old 06-18-2017, 04:40 AM   #5
Rewards Points: 898
Are you talking about one of these? If so, they do fail from time to time. Most municipal water suppliers mandate testing every few years.
https://www.amazon.com/Zurn-1-720A-W...8&s=industrial
Edw likes this.
BIG Johnson is offline   Reply With Quote
Old 06-18-2017, 07:13 AM   #6
Edw
Rewards Points: 38
Thanks again Msradell. I will replace the part.
The Following User Says Thank You to Edw For This Useful Post:
Msradell (06-18-2017)
Old 06-18-2017, 07:17 AM   #7
Edw
Rewards Points: 38
Hello BIG Johnson. Thanks for the post. That is similar. Mine has a Solenoid Valve connected with the Anti-Syphon Valve(Back Flow Preventer). I will replace this one.
Msradell likes this.
DIY lawn sprinkler system Red Squirrel Landscaping & Lawn Care 16 09-01-2017 08:10 AM
In-ground Sprinkler System Doesn't Work Budfudder Landscaping & Lawn Care 10 09-23-2016 04:48 PM
Sprinkler system Italgrl Landscaping & Lawn Care 3 05-22-2014 10:39 PM
Well water to sprinkler system questions C_J_GO Landscaping & Lawn Care 8 01-30-2013 09:34 AM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 05:23 PM
