Sprinkler Repair Questions - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-05-2018, 05:18 PM   #1
Rewards Points: 52
Sprinkler repair questions
I had a zone stop working on Sunday. When I turned it on the first head in the series started sputtering and stopped. The other three zones are functioning normally. I checked the box and there is a small dripping from only this zone so I am assuming that either the solenoid and or the valve itself is bad
I am planning on replacing it with a new valve. I know I need to turn off the water. I believe I have a Stop & Waste valve and need to get a curb key so that I can turn it off. ( it is 6' below ground). Do I need to bleed the valve? do I need to mess with the back flow preventer?
TIA
Z
zymurgist is offline   Reply With Quote
Old 06-05-2018, 05:43 PM   #2
Rewards Points: 1,042
Re: Sprinkler repair questions
I can turn mine off at the back flow preventer, take a look at yours and see if you can too.
Canarywood1 is offline   Reply With Quote
DIY Shoe Repair ddawg16 General DIY Discussions 12 02-13-2015 06:04 PM
Roof repair versus reroof and which contractor to believe? miamicuse Roofing/Siding 42 01-12-2015 09:05 AM
Shower Questions - Crack in pan / Tile Repair / Caulk question cjaustin81 General DIY Discussions 26 10-28-2014 05:10 PM
Front porch repair and questions Gurren Concrete, Stone & Masonry 2 10-10-2014 03:06 PM
Crawlspace mold repair questions jeep4dog General DIY Discussions 2 11-04-2011 07:03 AM
