Sprinkler Head Recommendation For A 7' Wide Strip - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 11-10-2015, 03:54 PM   #1
Rewards Points: 2,412
Sprinkler head recommendation for a 7' wide strip
I have a seven feet wide strip of a side yard.
It is 7' wide, and 36' long.
One side of it is the house exterior wall, concrete block stucco.
The other side is a masonry wall fence, also stucco finished.
What is the best kind of sprinkler heads to use for this kind of lawn? I know there are heads made specifically for narrow strips, but from past experience they don't really cover a rectangular area it's more like an "irregular bow tie" if that makes sense.
I am trying to decide:
(1) Where I should position the heads, in the middle (3.5' off), on the house side, or on the fence wall side.
(2) What type of heads to use.
Now ideally, I would never even put grass in this area. However, the house was a recent purchase and came with city liens. Last owner had removed too much grass area, and the city stepped in and ordered him to comply with the new code which is 40% landscaped area. With the entire site being 6000SF, of which 2400 of it is the actual house. If I want to keep the driveway to be concrete, I have to turn all available remaining space to grass. Which leads to many unpractical, stupid grass areas.
miamicuse is offline   Reply With Quote
Old 11-10-2015, 04:17 PM   #2
Rewards Points: 188
For such a narrow area, probably have to go with spray heads on both sides.
You would have a semi circle pattern from the spray with the heads staggered so the semi circles overlap.
X= head
X------X-------X-------X
---X-------X------X
http://www.rainbird.com/landscape/pr...iesNozzles.htm
Dan
djlandkpl is online now   Reply With Quote
Clipped Head v. Full Round Head Nails RickT Carpentry 10 11-18-2010 09:00 AM
Shower Head Breaking Off mbarnes Plumbing 3 01-11-2009 06:38 PM
Aerating worries - 50 head sprinkler system? J187 Landscaping & Lawn Care 2 05-04-2007 01:12 PM
