Sprinkler Head Help - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-08-2019, 06:03 PM   #1
Rewards Points: 24
Sprinkler head help
Hi all, attached is a picture of a pipe that was not capped properly and if I put the timer on a certain zone, water obviously starts gushing out of it. My temporary solution was just to skip the zone and it has been fine but I was thinking about putting a head there but have no clue what I’m doing lol.
Is there another piece of pipe I should be looking for that would normally connect to this or could I just install a head on this pipe and be set? Sorry for the stupid question, I am trying to learn as I go here.
Thanks for the help
Jason7613 is offline   Reply With Quote
Old 04-08-2019, 06:27 PM   #2
Rewards Points: 576
Re: Sprinkler head help
Dig back until you find from where the broken piece originates. Is it threaded or glued into the origin. Was there a broken sprinkler head anywhere ?
Cedrus is offline   Reply With Quote
Old 04-08-2019, 06:38 PM   #3
Rewards Points: 3,464
Tons of videos to watch on that.
LawnGuyLandSparky is online now   Reply With Quote
Old 04-08-2019, 06:53 PM   #4
Rewards Points: 24
Yes I’ve seen there’s a bunch of videos but I didn’t know if it was that simple but I’ll give that a shot. Thanks again
Old 04-08-2019, 06:53 PM   #5
Rewards Points: 7,556
So is there 3 or more sprinkler heads on that zone, and one is just plain missing?
Yes, you can add replace the sprinkler head. What size is the line? What I have seen is that they normally run a line of 1" inside diameter "funny pipe" from the valve, along the zone and then take off 3 or more perhaps 2' long pieces of smaller tube (maybe about 5/8" ID) to each sprinkler head (easier to bend the hose).
You will likely need to find a landscape supply place for the components. The sizes of the tube are not the same as what the hose barb fittings you find at the home depot plumbing department stocks for hose. (But you HD might have a good landscape department.)
Don't buy cheap sprinkler heads. As you have probably figured out, these things have a certain amount of maintenance. Unless you enjoy digging in the dirt (mud), buy a good head that may have less maintenance.
Also, before you connect the head, run the zone for a few minutes to flush out any dirt that got into the hose. Actually, cap it now so that no more dirt gets in there.
SPS-1 is online now   Reply With Quote
Old 04-12-2019, 08:30 PM   #6
Rewards Points: 24
Thanks for the help. It’s a 3/4in pipe so would I just need an elbow that fits and then the actual sprinkler head to screw into it?
Old 04-12-2019, 08:31 PM   #7
Rewards Points: 24
Also what are decent brands for sprinkler heads? Thanks
Old 04-17-2019, 01:56 AM   #8
Rewards Points: 268
Just replace it with the same brand that you have in the rest of the yard.
Take the pic of the broken pipe and the name of the sprinkler head to HD or Lowe's and they should be able to help you out.
DallasCowboys is online now   Reply With Quote
Old 04-17-2019, 10:48 PM   #9
Msradell's Avatar
Rewards Points: 818
Thanks for the help. Itís a 3/4in pipe so would I just need an elbow that fits and then the actual sprinkler head to screw into it?
You can do it that way but the better way to do it is to put a short piece of flexible hose between the hard pipe and the sprinkler head. That makes it much less likely to have a problem in the future.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
What type of inground sprinkler head should I purchase? TJLongIslandNY Landscaping & Lawn Care 2 05-04-2017 10:02 AM
Inground sprinkler system SPLITTER? TJLongIslandNY Landscaping & Lawn Care 3 09-09-2016 06:23 PM
Sprinkler conversion from spray head to drip kevinf. Plumbing 3 04-25-2013 02:02 PM
sprinkler head stuck wont come up tven Plumbing 14 04-13-2013 01:25 PM
ceiling tile replacement around sprinkler head LanterDan General DIY Discussions 4 10-29-2009 06:39 PM
