Sprinkler Control System - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-18-2018, 04:19 PM   #1
I just purchased a new home and for the life of me I cannot find the sprinkler control box. I have looked everywhere. Is it possible to run the sprinklers without one? There are probably 15 sprinkler heads throughout the front and back yards. I am seriously stumped. There's an irrigation control box out by the street but it only has one valve and when turned it doesn't do anything.
tylerwinckler is offline   Reply With Quote
Old 07-18-2018, 04:40 PM   #2
Rewards Points: 7,548
Re: Sprinkler Control System
Control box needs power, so it needs someplace to be plugged into. Mine is in my garage. You will have one or two valve boxes in the ground ---- possibly one if your area is not too big, or if water supplied from a central location, possibly one valve box in the front, one valve box in the back. To minimize wiring and trenching, controller is expected to be close to one of the valve boxes.
SPS-1 is online now   Reply With Quote
Old 07-18-2018, 05:49 PM   #3
Rewards Points: 1,042
Your back flow preventer should give you a clue, also an electrical line going inside the building.
Canarywood1 is offline   Reply With Quote
Old 07-18-2018, 06:01 PM   #4
Guapo
Rewards Points: 11,950
Also, there should be a valve & a pipe that gives you a clue too.
Guap0_ is offline   Reply With Quote
Old 07-18-2018, 09:22 PM   #5
Msradell's Avatar
Rewards Points: 818
Call your realtor, they are really pretty good about giving you information about features of your home. Or else if you know who owned it previously just give them a call or drop them a note.
If you feel like hunting, as mentioned previously in the garages the first place to look. Some controllers are also weatherproof and can be placed outside, do you know where your backflow preventer is for the sprinkler system? If so I would start looking around there. Another place I see them is in your basement (if you have one).
They are normally a relatively small box, 8"-10" square are so.
Written using Dragon Naturally Speaking
Msradell is online now   Reply With Quote
Old 07-26-2018, 11:26 PM   #6
Rewards Points: 122
It's possible to run sprinklers without the conventional sprinkler control valves but they'd require some sort of operating valve. No sign of an underground valve box? Maybe it's buried behind a bush or in a garage or shed?
Joeycarnuba is offline   Reply With Quote
Battery or Alternator JBG420 Automotive Repairs 25 11-11-2017 06:56 AM
My sprinkler system will never run again mj12 Landscaping & Lawn Care 1 06-20-2016 06:12 PM
How to turn on sprinkler system? shovad Landscaping & Lawn Care 12 06-19-2016 10:42 AM
Help rewiring control system for multistage heat pump ink HVAC 12 12-10-2012 09:23 PM
Assistance on Toro sprinkler system Dgreaney Landscaping & Lawn Care 5 06-12-2011 08:38 PM
