Sprinker Startup Question - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-01-2017, 06:30 PM   #1
Rewards Points: 12
sprinker startup question
Hello all - please be gentle because this may be a really dumb question.
I was trying to startup my sprinker system myself and watched a couple of videos on how to do it.
basic steps I tried to follow -
1. Make sure the petcocks are tight.
2. Ball valves are closed.
3. Turn on water in basement
4 - Then planned on slowly opening the ball valves outside
Now, in the part that is outside the house with the two ball valves and backflow part is - has a hose bib/drain type thing there.
I didn't see this part in any of the videos I saw - some of them refer to a drain near the main water supply but I don't have that.
That was open , so when I tried turning on the main water supply from the basement, it flows out of there ouside - since the ball valves (?) are still closed.
I am assuming I need to shut that tight and then turn on the water?
I hope this makes sense. TIA for any input !!
yasvish is offline   Reply With Quote
Old 06-02-2017, 01:49 PM   #2
Rewards Points: 44
Re: sprinker startup question
Close everything outside.
Open the valve inside. No water should flow at this point.
Open the first petcock (closest the supply)
Open the second one.
Turn on your sprinkler system.
Manually step through the zones allowing the air to purge from each one.
Done.
My company wants $40 bucks from me for that. It takes all of five minutes and requires no special equipment or knowledge. No thanks.
abrowning is offline   Reply With Quote
Old 06-02-2017, 01:58 PM   #3
Rewards Points: 12
Thank you ! That really helped ( closing everything outside ) and gave me the confidence to try it and it worked !!
Thank you so much . Around here they charge -$45-$50 for this ..so this does help
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
Plumbing for new shower kit question noviceshock Plumbing 6 03-02-2013 08:11 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
