Spreading Fertilizer Pellets, Uneven Coverage Still Works? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 1 Post By Colbyt
  • 2 Post By SeniorSitizen
  • 2 Post By Colbyt
Old 05-27-2018, 05:01 PM   #1
Rewards Points: 430
spreading fertilizer pellets, uneven coverage still works?
18 pound bag covers 5000sqft.
at 3.6lb per 1000, the pellets were scattered sparsely.
how's the grass supposed to get the nutrients like this?
pman626 is offline   Reply With Quote
Old 05-27-2018, 05:38 PM   #2
Rewards Points: 1,858
Re: spreading fertilizer pellets, uneven coverage still works?
The only thing I can figure is they are counting on the pellets to melt with the rains, and then the fertilized water will spread out in a certain circumference sized circle = more coverage ? I dunno...
Gregsoldtruck79 is offline   Reply With Quote
Old 05-28-2018, 06:02 AM   #3
Rewards Points: 6,997
It does, how I can't tell you. Put too much and you will learn. I'm challenged spreading it that thin so at the rentals or for new seeding I use 10-10-10 and apply enough to see the coverage.
Gregsoldtruck79 likes this.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 05-28-2018, 06:51 AM   #4
Rewards Points: 1,488
The - "actual" - amount of each element applied is what's important and not so much the pounds in the bag that will cover XXX sq. ft.
https://plantscience.psu.edu/researc...-fertilization
Colbyt and Gregsoldtruck79 like this.
Old 05-28-2018, 11:45 PM   #5
Rewards Points: 576
It is better to use fertilizer sparingly. It is food....not medicine. Two light feedings 30 days apart is better than one heavy feeding...in most cases. Post#4 has it right.
Cedrus is offline   Reply With Quote
Old 05-29-2018, 07:05 AM   #6
Rewards Points: 6
Check out Milorganite for a fertilizer that you can spread heavy and not have to worry about burning your lawn. It breaks down slowly and works into the soil instead of dissipating to the atmosphere.
w0j0 is offline   Reply With Quote
Old 05-30-2018, 01:15 AM   #7
Rewards Points: 430
I have no problem spreading it thin. I was just curious how the plant gets food with 10% coverage. I was thinking the greening would be spotty this way.
I just laid down 3.8 pounds of 18/24/6 starter fertilizer, and it's mostly slow release, so I probably couldn't burn the lawn if i put a little extra.
I'll find out later this week if my rental house grass shows any change.
Old 05-30-2018, 02:31 PM   #8
I can't explain the 'how' but spread as directed you get even greening.
Msradell and Nik333 like this.
Colbyt
