Spraying Horticultural Vinegar - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 12-17-2016, 02:24 PM   #1
Rewards Points: 201
Spraying horticultural vinegar
Any concerns about the acidity- 20% vinegar- affecting parts of sprayers? I am looking at this sprayer- https://www.amazon.com/Operated-Fert...5Z96EXA29VDPQZ
elmaur is offline   Reply With Quote
Old 12-17-2016, 10:29 PM   #2
Msradell's Avatar
Rewards Points: 832
Re: Spraying horticultural vinegar
As long as you rinse the sprayer out soon after you finish spraying it shouldn't be an issue. I wouldn't let the vinegar solution stay in the sprayer over a long period of time however. For a regular pump up sprayer it probably never would be an issue but considering this one has a pump inside I wouldn't take any chances.
Written using Dragon Naturally Speaking
Msradell is online now   Reply With Quote
Old 12-18-2016, 10:51 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Ayuh,..... Regardless what sorta sprayer ya use, it'll need to be flushed out really good after use of acid, or chlorine,....
Repeated flushin' with water should save the sprayer,....
I know, I've ruined a few,.....
As for what yer tryin' to do with the vinegar, I'd use Clorox,.....
Clorox is very, Very effective in killin' weeds right down to the root, 'n dissipates fairly quickly without adverse effects on the surroundin' environment,...
Spraying Kitchen Cabinets beautyfish Painting 2 03-07-2015 06:52 PM
Very impressed by white vinegar as rust remover! stripedbass General DIY Discussions 12 01-26-2015 09:36 AM
tankless water heater flush - vinegar discolored autx790 Plumbing 3 10-10-2013 06:32 AM
Calling Pro Painters - Airless Spraying mobiledynamics Painting 9 09-19-2012 09:51 AM
Vinegar in the Washing machine wraiththe Plumbing 6 01-12-2012 10:51 PM
