Splitting The Main Sprinkler System Line - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-27-2018, 10:27 AM   #1
Rewards Points: 34
Question
Splitting the main Sprinkler system line
I have a sprinkler system currently with 4 zones. I have rachio control setup which can take upto 8 zones. Excuse the drawing. Orange dots are sprinkler heads.
I'm considering extending to 8 zone. zone 4 is all the in the back of the house near my garden area. This is where I want to install the second inground box so I can 4 more zones.
My question is, Can I split the black water main and remove current zone 4 pipe and connect it to the split water main and use the red pipe as my second water main? Then have this red pipe go to the second box which will then feed additional 4 zones? I will run separate wires to the rachio box from the second inground box.
The reason for this is so I don't have to dig a new pipe all the way to the second box. This is more than 150ft.
All pipes are poly tubing but I can't remember what size.
sam240 is offline   Reply With Quote
Old 08-06-2018, 10:05 AM   #2
Rewards Points: 122
Re: Splitting the main Sprinkler system line
From what you describe it sounds possible. You'll want to figure out the pipe size of the red line to ensure it's large enough to provide the flow you need to run your new zones.
I noticed you only have 3 heads per zone, do you have pop-ups or rotary heads?
Joeycarnuba is offline   Reply With Quote
Tags
irrigation system , sprinkler irrigation , sprinkler pipes
Sprinkler system Italgrl Landscaping & Lawn Care 3 05-22-2014 10:39 PM
New Guy Here. Main water line question... Freestyler Plumbing 8 11-26-2012 07:59 AM
Main Line Clog Master Brian Plumbing 46 09-06-2012 08:38 PM
Re-routing main water line (perpendicular to joists) near ductwork and gas line? jjcatal Plumbing 1 03-29-2011 10:18 PM
leaky copper fitting in supply line for fire sprinkler system tina2435 Plumbing 5 09-18-2009 09:54 PM
