Spacing Between Stone - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree6Likes
  • 1 Post By Shelby2098
  • 1 Post By de-nagorg
  • 3 Post By Shelby2098
  • 1 Post By Windows on Wash
Old 05-25-2019, 10:30 PM   #1
Rewards Points: 18
Spacing between stone
Hello,
I'm putting "9x9" stone in a 54"x36"area outside my shed that can't grow grass and turns to mud when it rains. I am not staggering the stone and was wondering if I need to leave a gap between the stones, or just but them up together and put the sand over it. Thanks!
Tim
Shelby2098 is offline   Reply With Quote
Old 05-26-2019, 07:38 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,642
Re: Spacing between stone
You can butt them together usually. Is this an engineered stone?
Old 05-26-2019, 08:56 AM   #3
Rewards Points: 18
Not sure. Here is a picture.
Old 05-26-2019, 09:07 AM   #4
Engineered stone. Zero gap should be fine.
Old 05-26-2019, 09:43 AM   #5
Rewards Points: 18
Thank you!
de-nagorg likes this.
Old 05-26-2019, 10:28 AM   #6
JUSTA MEMBER
Rewards Points: 4,068
Actually, they are designed to be butted together, with an edging to hold them securely in place, and the sand vibrated / tamped, between the joints.
It should not take much sand, if you have them edged securely in place.
ED
Windows on Wash likes this.
de-nagorg is offline   Reply With Quote
Old 05-26-2019, 10:42 AM   #7
Rewards Points: 18
Just the black standard edging around the area and then backfill with sand then topsoil? Would just back filling with sand and topsoil be adequate? It's just a small area in front of a shed.
Old 05-26-2019, 11:54 AM   #8
JUSTA MEMBER
I must have misunderstood, you're wanting to use these as "landfill"?
Not for the paving purpose of everyone else?
Then why spend the extra $ for something that you are burying, just use the grey CMU material that costs less $.
These are the 8" x 16" x3"thick blocks.
And if you are not paving with them, and just burying, the edging is not necessary, because the surrounding ground should hold them securely enough that they won't shift, with the soil and turf atop them.
ED
Old 05-26-2019, 12:08 PM   #9
Rewards Points: 18
They will be at grade. Here is what I have so far. Gravel 4" below grade and putting in 2" sand and the 2" for block. I was just going to fill around the exterior with topsoil.
Old 05-26-2019, 12:11 PM   #10
Rewards Points: 18
Picture...
Old 05-26-2019, 01:10 PM   #11
JUSTA MEMBER
All right!.
You have the basics there, just need the black edgings, to secure the pavers, and then the sand in the spaces.
and your side dirt, to raise the area up to "GRADE".
Should be a much cleaner area after the work is completed, all mud gone, and safer for you to step on too.
ED
Old 05-26-2019, 07:10 PM   #12
Rewards Points: 18
Final product. Tossed some mulch in their for now.
Old 05-27-2019, 08:03 AM   #13
Well done. Looks clean!!!
My new Ultra Sharp Diamond Sharpening Stone set Drachenfire Tools 10 01-08-2018 11:38 AM
Stone house wall insulation Huckleberry17 Insulation 17 10-19-2017 08:11 PM
The Stone Veneer Is Falling Off JulieMor Concrete, Stone & Masonry 30 09-29-2013 10:00 AM
Changing the color of stone misayo Interior Decorating 3 01-16-2012 02:59 PM
Another stone facing thread... paredown Building & Construction 0 12-06-2011 03:27 PM
