Some Sort Of Tank/barrel Buried In Yard? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-14-2011, 08:44 AM   #1
Some sort of tank/barrel buried in yard?
While working on sprucing up my humble yard, I came across an oil drum sized (?) barrel buried about a meter and a half away from the end of the driveway. I honestly have no idea what it's for, and I'd like to just bury it again and put field stone and concrete over it to add two meters or so to my driveway. It's pretty far down, more than half a meter, I just noticed my shovel hit something metal when I was digging so I excavated some more to see what it was.
Any idea why someone would bury a barrel like this? I'm not sure exactly how big it is or long, but it can't be a pipe since it would have nowhere to flow, also it sounds a bit hallow when I bang on it. It would be so much work to excavate it...
NorskeDiv is offline   Reply With Quote
Old 07-14-2011, 09:07 AM   #2
the Musigician
DangerMouse's Avatar
It sounds like a drainage pipe to me. Is it horizontal? Perpendicular to the driveway?
Is there a drainage ditch on either side of your drive? Can you post us a picture?
DM
Old 07-14-2011, 09:36 AM   #3
A Little Of Everything
Rewards Points: 1,420
Old septic tank?
DrHicks is offline   Reply With Quote
Old 07-14-2011, 09:50 AM   #4
Rewards Points: 558
Unless you found where Jimmy Hoffa was buried and that drum has no inlet or outlet to drain water it could be someone buried a metal drum during construction stage. I have found in the past all kinds of things buried from blocks, tools, spools of cable and even part of a scaffold. If your not sure what it is I would try contacting the city to verify if in deed it is just that a buried metal drum with no use that way you can either bury it again or remove it without problems… And yes please do supply pictures because at this time with the description provided it is only speculation on our part on what this could be.
epson is offline   Reply With Quote
Old 07-14-2011, 08:36 PM   #5
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 12
Where you are located? It could be relevant.
Possibly some type of fuel tank? A common practice in one area of the country may be unheard of in another.
Edited to add: I just noticed you use meters for measurement. Are you in the US?
Old 07-14-2011, 10:28 PM   #6
Time Capsule or Emergency Stash if its Sealed. I know quite a few people in the "Survival Community" that Keep "Stashes" Burried and marked in case SHTF!
Stubs is offline   Reply With Quote
How to Grade Forever-Flooded Yard? TheMedicsWife Landscaping & Lawn Care 1 04-12-2010 12:46 PM
Uphill neighbor says I'm flooding his yard.. EdwardC Landscaping & Lawn Care 10 04-11-2010 11:03 PM
Front yard decorating tips jay_chua Landscaping & Lawn Care 1 03-10-2010 08:00 AM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
A hot wire buried in the yard that you cannot even trip a breaker by sharting it? BJLower Electrical 3 01-21-2010 03:24 PM
