Some Sort Of Drywell Needed. - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By Bondo
  • 1 Post By Bondo
Old 04-30-2017, 10:36 AM   #1
Rewards Points: 307
Some sort of drywell needed.
I don't know if this is the right section for this but here goes. I had my backyard redone a few years ago and when they graded the concrete and pavers the water runs to the gate leading out of the yard. Now the area in front of the gate gets saturated and turns to mud. As a temporary repair I made a hole about 3 feet by 3 feet and about a foot deep and put crushed stone in there. It worked for awhile but now that has become saturated and the area around there is now muddy. So now it is a big mess.
I would like to add a dry well to in front of the gate area. I would need a grating on top of it to allow the water to flow into the well. I know how to dig the hole and put stone around it but from there I would need some guidance. Like how to set up the top for the grating.
stevez is offline   Reply With Quote
Old 04-30-2017, 11:09 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Re: Some sort of drywell needed.
Ayuh,.... Another dry-well is gonna do the same thing, fill up, 'n make a mess,....
Regrade the area, 'n pitch the water away,....
MTN REMODEL LLC likes this.
Old 04-30-2017, 04:54 PM   #3
Rewards Points: 307
Can't regrade the area it is concrete and pavers. There isn't a dry well there now. It is a hole with rock in it.
Any ideas on a dry well.
Old 04-30-2017, 06:35 PM   #4
Bondo's Avatar
Ayuh,.... Which is what a dry-well is,....
Old 04-30-2017, 07:27 PM   #5
Rewards Points: 307
Ayuh maybe the one I was thinking of has a 55 gallon drum in the ground with some sort of gravel around it. maybe a grill over something to catch the water and then some sort of pipe to bring it to the 55 gallon drum.
Maybe someone that actually did one can chime in and let me know how they did it.
Old 05-01-2017, 02:30 AM   #6
jlhaslip's Avatar
Rewards Points: 708
I have used a Bobcat with an auger to drill a hole 8 ft deep and filled it with a sonotube then gravel. Worked fine, but it depends on the volume of water and the soil's associated Perc Rate to function properly. If the deep soil does not drain well, you run the risk of overflowing.
Cover the top with a soil fabric so it doesn't fill with dirt.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 05-01-2017, 08:57 AM   #7
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,274
No way to bore (water drill) under the concrete and pavers and run some PVC drain to a lower area/street.......?????
I'm kinda lost as to what a 55 gallon drum is going to do for you... at least after 55 gallons of rain falls.
MTN REMODEL LLC is online now   Reply With Quote
Building a 20' x 20' wood frame garage bgbrown125 Building & Construction 38 08-07-2011 01:53 PM
extra circuits needed for expanded basement? denemante Electrical 5 05-31-2011 10:55 AM
Need advice on quantity of primer and paint needed laurat Painting 8 01-01-2011 10:53 AM
Combustable air, how much is needed? Lee Roy HVAC 9 10-27-2010 10:17 PM
Soundproofing help needed! Janis General DIY Discussions 7 09-10-2007 01:40 PM
