Soil Retention/drainage Issue - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-28-2014, 07:18 PM   #1
Rewards Points: 14
Soil retention/drainage issue
The area in this pic is essentially a drainage alley. Water flows out of my gutter and drain and my neighbors driveway etc. into the area that you see which then flows into a drainage ditch behind the fence. The area near the foundation of the garage is eroding some and always pretty muddy. Is there any recommendation anyone has for retention of the soil or otherwise? I was thinking of planting some hostas or liriope or anything else that my do a good job there. Or would I be better off putting gravel or something in the area? It is obviously a shady and wet area. Thanks in advance for any help with this.
Soil retention/drainage issue-img_20140425_183053.jpg
hstanfield is offline   Reply With Quote
Old 04-28-2014, 07:51 PM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,650
Originally Posted by hstanfield View Post
...which then flows into a drainage ditch behind the fence.
I'd find a way to direct that water to the street.
Old 04-28-2014, 07:55 PM   #3
Rewards Points: 14
Tarheel,
I wish I could but it would be nearly impossible. Even if I could get mine to go that way, the neighbor's water from their driveway goes down that way as well and the street is probably 100 ft away in the other direction. In fact the whole neighborhood's water runs that way because of the layout of the land!
Soil level is above vinyl siding/foundation DoctorWho Building & Construction 9 08-07-2011 07:53 AM
Compost or top soil requirement cprao Landscaping & Lawn Care 10 12-28-2010 05:01 PM
Grading soil away from the house barkie Building & Construction 3 07-09-2010 09:05 PM
soil grading for basement moisture jpenns Landscaping & Lawn Care 4 07-15-2009 09:44 PM
