Snowblower Shuts Off After 10-15 Minutes - Landscaping & Lawn Care - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-03-2015, 07:00 AM   #16
No no sensor
Sent from my SM-N900W8 using diychatroom.com mobile app
chillz911 is offline   Reply With Quote
Old 02-03-2015, 12:39 PM   #17
Rewards Points: 107
Sounds like it needs to have the carb rebuilt or replaced. Dirt, vibration etc. you could try closing the choke a little.
jimn01 is offline   Reply With Quote
Old 02-03-2015, 05:09 PM   #18
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,650
I think you said you checked the gas tank. Back in my teen years I had a 54 ford and lost the gas cap, I stuck a shop rag in the gas filler to keep trash out. The rag disappeared, I thought it blew out, it didn't it went down in the tank.
I would be driving along and the car would die, but it would crank right back up. Like to have never figured it out. The rag would get sucked against the pickup tube and kill the engine. When dead, the rag would drop off and it would fire right back up.
One thing I can think of right off hand is your gas line might be getting warm then collapsing. Also a bad coil will do like that also. But by pumping the bulb and it brings it back up, something is stopping the flow of fuel.
I thought of the gas cap also, on a boat fuel tank there is a vent screw, if it is closed it will cause a vacuum in the tank to the point it will not allow gas to be pumped out, starving the carbs.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 01-12-2016, 12:56 PM   #19
I changed the coil recently...and I have the same problem. I'm going to try to use high test gas to see if it makes a difference...if that don't work I'll have to bring it in to get fixed
Old 01-12-2016, 01:19 PM   #20
Rewards Points: 1,506
If running with the air filter try running without. Sometimes under winter conditions they ice over.
Old 01-26-2016, 12:25 PM   #21
Update-
Ran the blower with regular gas to empty the tank and added sea foam.
Used super or high test gas and now it works like a champ...Damm you ethonol gas you won...problem solved
Old 01-26-2016, 01:23 PM   #22
WhatRnsdownhill's Avatar
Rewards Points: 2,220
get a can of marine stabilizer the green color, works wonders with the crap ethanol gas..
WhatRnsdownhill is offline   Reply With Quote
Old 01-26-2016, 08:55 PM   #23
Davejss's Avatar
Rewards Points: 896
I started running premium gas with some Stabil in all of my small engines. No more carb problems at all.
Davejss is offline   Reply With Quote
Old 01-26-2016, 09:22 PM   #24
Rewards Points: 5,348
There's an adjustment screw on the bottom of the carb bowl. Play with it.
Ron
B. Franklin 1759
Lennox Whisperheat runs normally but shuts off after 5-30 minutes sumguy HVAC 25 02-01-2013 12:20 PM
Septic Pump running every 10 minutes for a 2.5-3 minutes phuz Plumbing 5 01-31-2013 08:08 PM
Condensor fan shuts off after exaclty 10 miutes KP616 HVAC 5 08-07-2012 10:39 AM
Payne furnace, shuts off after 5 minutes rcarlson254 HVAC 1 03-14-2012 01:31 PM
Armstrong Ultra SX 90 shuts off early. jonmar HVAC 0 11-04-2010 05:58 PM
