Slope For Stormwater Drain 4" - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 2 Post By bob22
Old 08-01-2017, 09:38 PM   #1
Rewards Points: 336
Slope for stormwater drain 4"
What slope do you guys use for 4" pvc pipe stormwater drains? Is 1" per 10 ft not enough? I usually just add a piece of scrap wood to the bottom of my 4 ft level and go that route. If I put a piece of 1/2" wood, I would be looking at 1 1/4 drop over 10 ft. If I do 3/4 wood at one end of the level, I'm looking at 1 7/8" over 10 ft.
weatheredwood is offline   Reply With Quote
Old 08-01-2017, 10:37 PM   #2
retired framer
Rewards Points: 20,472
Re: Slope for stormwater drain 4"
Any off that will work, there is a formula for moving sand and stuff with the water, not sure how that works.
Old 08-02-2017, 06:33 AM   #3
Rewards Points: 2,378
"According to the International Plumbing Code, drainage pipes should be run with a uniform slope at the following minimum pitches:"
PIPE DIAMETER MINIMUM SLOPE
2 1/2" or smaller 1/4" per foot
3" to 6" 1/8" per foot
8" or larger 1/16" per foot
Source: https://www.archtoolbox.com/material...ipe-slope.html
lenaitch and Nealtw like this.
bob22 is offline   Reply With Quote
Running new kitchen drain because 1953 wasn't friendly with connection height scgt1 Plumbing 16 02-03-2017 11:57 AM
How to slope floor for drain in Sauna Kyanite Flooring 7 10-12-2016 04:21 PM
Rusted and almost gone drain pan, Package unit Nordyne kilosos2 HVAC 3 11-18-2012 09:24 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
drain slope ouchmythumb Plumbing 2 05-12-2007 05:12 PM
