Seating Wall Footing Depth - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By jlhaslip
Old 04-04-2017, 05:46 PM   #1
Rewards Points: 4
seating wall footing depth
hi everybody
need some advice
here in Chicago I'm building new brick patio approx 24'x16' with the wooden pergola in one corner and the 16"-18" high seating wall around it
to make all project sturdier I want to pour the footing for the seating wall. while the pergolas posts will be buried in in concrete below frost line at 48". seating wall footing I will make 6"-7" wide and 24" deep with 2 lines of rebar.
do you think seating wall footing should be deeper? wider? should I put 4 lines of rebar instead of 2? should I put few inches of gravel under the footing and then compact it before pouring the concrete? any additional thoughts you have - please share. thank you for your help!
muzhikas is offline   Reply With Quote
Old 04-04-2017, 07:40 PM   #2
jlhaslip's Avatar
Rewards Points: 708
Re: seating wall footing depth
Originally Posted by muzhikas View Post
hi everybody
need some advice
Typically, the footer for the brick half walls would be set below frost line same as the post bases. The footer is also (usually) wider than the brick wall so the weight is spread out over a larger area. How much wider? Depends on the soil and its ability to resist loads. Check around locally and find a concrete guy or experienced builder or check with the local Building Inspector.
Not a bad idea to tamp the bottom of the footing after excavation. Normally no gravel would be required under the concrete and, depending on the soil, it way be required to provide weeping tile drainage at the footer. Again, find a local to assist with these questions. If you are in a sandy soil, you build differently than a clay soil. Depends on the soil's ability to drain itself, called a Perc test, often used in the design of septic fields, etc.
muzhikas likes this.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Wall damage below bathroom quaker87 Plumbing 8 02-28-2013 04:56 PM
How to Square a Wall or Layout for a Foundation BigJim How To Guides 2 01-31-2013 09:48 PM
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 03:11 PM
enclosing garage, non-load bearing stucco wall - do I need to cut slab & dig footing? eric559 Building & Construction 3 07-07-2010 01:41 AM
Extend Footing Depth cibula11 Building & Construction 10 08-18-2009 02:59 PM
