Screening All Wet Under Patio Stones - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 06-25-2017, 07:52 AM   #1
Rewards Points: 38
Screening all wet under patio stones
I'm having my 2x2 patio stones levelled again. When the guy removed the stones, it was all wet and the screening was mixed with earth so I'm assuming it couldn't drain properly or wasn't tamped down properly. Could someone please confirm what size stone should be used and the proper order of doing things. Thank you.
Gbunny100 is offline   Reply With Quote
Old 06-25-2017, 08:28 AM   #2
concretemasonry's Avatar
Rewards Points: 2,716
Re: Screening all wet under patio stones
Gbunny100 -
For a patio stone application, the top soil and organics must be removed. Next a fabric filter blanket should followed by your compacted base and a 1" setting bed of sand screeded level. Set the patio stones on the sand bed, sprinkle fine sand over the patio surface and vibrated with a plate compactor to even up the surface and get sand into the tight joints to add strength and stability.
If your land is "dead-flat" digging out any soil will create a hole to collect water if the soil below is impermeable and there is no way out.
Your location and soil type may have a bearing on the details.
Dick
concretemasonry is offline   Reply With Quote
The Following User Says Thank You to concretemasonry For This Useful Post:
Gbunny100 (06-25-2017)
Old 06-25-2017, 01:22 PM   #3
Rewards Points: 1,042
If there's dirt mixed in with the base course, that's more than likely the problem, the entire patio should be excavated to a depth of at least 8 inches, and replaced with crusher run stone compacted in at least two lifts, with one inch of sand on top of that for your setting base.
3/4" to dust crusher run would be ideal for what your doing, here's a link.
http://www.braenstone.com/2014/12/crusher-run-uses/
Canarywood1 is offline   Reply With Quote
The Following User Says Thank You to Canarywood1 For This Useful Post:
Gbunny100 (06-30-2017)
Patio door slider screening carlsimmons1969 General DIY Discussions 7 06-25-2015 09:19 AM
Wooden deck onto of patio stones zoolou Landscaping & Lawn Care 1 06-12-2013 08:50 PM
Transition from a new pitched patio to an existing level patio barlav Concrete, Stone & Masonry 1 05-03-2013 05:20 AM
Cutting patio stones Red Robin Building & Construction 5 07-29-2011 09:21 AM
laying small stones in mortar on a patio Gary Schenk Building & Construction 1 09-21-2009 09:27 AM
