Scott's Grass Seed Vs. Pennington Grass Seed - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-18-2016, 07:37 PM   #1
Rewards Points: 14
Scott's grass seed vs. Pennington grass seed
So question for everyone since I'm having a lot of troubles with scotts contractor mix grass seed. About 2 months ago I had doubled the size of my yard, I picked up a 20 lb bag of Scott's contractor mix and I am very disgusted with this seed. I've watered it and fertilized it and it has stayed a very light green color and has came in very thin. I picked up a 20 lb Pennington Midwest mix bag and I'm very pleased, from the beginning it's has grown a deep dark green and came in twice as thick in the same amount of area..my question is how do I fix the area where the Scott's was applied?
Gorilla03 is offline   Reply With Quote
Old 09-18-2016, 08:12 PM   #2
Rewards Points: 7,390
Re: Scott's grass seed vs. Pennington grass seed
Where are you located?
First, check the bags for exactly what types of grass seeds were in those bags. Many different types of grass. Could be very different types of grass.
Middle of July would be a terrible time to plant grass most places. Too hot and dry. Could be that just a few of the hardiest seeds survived the first planting -- and those might not be of particularly good looking variety of grass.
Many places, right about now is a perfect time to plant grass. Possibly best to just re-seed the first portion.
Myself, I don't seed anymore, I buy sod. Perfect lawn in a few hours.
SPS-1 is online now   Reply With Quote
Old 09-18-2016, 08:15 PM   #3
Rewards Points: 14
Wisconsin
Old 09-18-2016, 08:55 PM   #4
Rewards Points: 996
would you happen to be watering with softened water ?
Fix'n it is offline   Reply With Quote
Old 09-20-2016, 02:02 PM   #5
Rewards Points: 4,154
No way should you have seeded in Wisconsin in July, that's when lawns have gone dormant from the heat.
I think this is more likely the cause than the brand unless the bags contained different kinds of grass seed - typically, we're going to use a blend of perennial rye, bluegrass and red fescue.
stick\shift is offline   Reply With Quote
Old 09-20-2016, 07:19 PM   #6
Rewards Points: 1,748
Check the use-by dates on the bags, you may have been stuck with some old stuff.
ChuckF. is online now   Reply With Quote
Old 10-12-2016, 05:15 PM   #7
Rewards Points: 66
In addition to the sound comments from others, I too had a lot of issues with even the top grade of Scott's and changed to Pennington. Results are much better.
keithhe is offline   Reply With Quote
Old 10-14-2016, 06:44 PM   #8
Rewards Points: 128
I usually just use bulk seed.
DIYknot is offline   Reply With Quote
Anyone have any luck with Scotts grass seed? Piedmont Landscaping & Lawn Care 34 05-14-2013 09:20 PM
Scotts EZ Seed. No go. DrHicks Landscaping & Lawn Care 13 05-12-2011 05:30 PM
Grass Seed is Not Generic - Get the Right Blend user1007 Landscaping & Lawn Care 7 04-29-2011 12:15 PM
New grass seed planted- next steps to fix problems? skittles1984 Landscaping & Lawn Care 9 03-13-2011 10:49 AM
grass seed rcassidy Landscaping & Lawn Care 2 02-27-2009 06:03 PM
