Is Rust Bad For Grass ? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By ddawg16
Old 01-15-2017, 07:45 PM   #1
Rewards Points: 996
is rust bad for grass ?
i have 2 buckets of rusty rusty water i need to get rid of. these buckets are very heavy, filled with cast iron. dumping on my driveway isn't an option. they are next to the DW, so dumping in the grass would eb easiest. but i am thinking rust is not ok for a lawn.
Fix'n it is offline   Reply With Quote
Old 01-15-2017, 08:43 PM   #2
Msradell's Avatar
Rewards Points: 818
Re: is rust bad for grass ?
You are correct, small quantities of rust are okay for grass but a large quantity like you have wouldn't be good for your grass unless you are able to disperse it over a large area. Your best bet to dispose of it safely would be just to dig a hole in the back corner of your property someplace and dump it into that. It was then soaked under the ground harmlessly. It really isn't harmful to the environment but it is to plant life in high concentrations.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 01-15-2017, 09:41 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 9,314
Pour part of the rusty water into another bucket....dilute with clean water....pour on the grass.
Repeat in a different spot.
Better yet....do it during a heavy rain
DexterII likes this.
Old 01-15-2017, 10:09 PM   #4
Rewards Points: 996
ok, thats what i thought. thanx
Steel studs rust basement help bergerdude Building & Construction 17 10-02-2013 01:24 AM
Rust converter (phosphoric acid) not working Studly Automotive Repairs 3 05-02-2013 06:57 PM
I-Beam, Rust & Concrete kinghong1970 Concrete, Stone & Masonry 13 03-29-2013 11:59 AM
Cleaning brush StevenH Painting 19 02-05-2011 11:13 PM
Seeking advice on severe rust buildup issue. YerDugliness Plumbing 2 05-07-2010 06:02 AM
