Rock Wall On Top Of 5 Feet Of Fill - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-17-2010, 08:25 PM   #1
Rock wall on top of 5 feet of fill
I am planning on putting an 18" high rock wall on top of five feet of fill. The fill is 3 inch minus over well drained sandy soil. Should I let the fill sit there through the winter before putting the rock wall on top? The wall is loose laid rocks and I don't want it settling so it isn't straight. This is in the snowy North East. Thanks
PerpetuallyRepairing is offline   Reply With Quote
Old 05-17-2010, 10:52 PM   #2
Civil Engineer
Rewards Points: 5,246
You can let the fill sit there forever, it is not going to compact by itself. If you compacted the fill when you put it in, typically using a vibratory compacter and 6 inch maximum lifts, you are good to go. If you did not compact the fill, it is going to settle, although if it is 3 inch minus crushed stone it won't settle much. Either way, the wall is only 18 inches tall, you are using loose rock, so I say go for it.
Old 05-29-2010, 07:58 AM   #3
I couldn't fine anyone to build a wall on top of uncompacted fill. Putting the wall on top of 8" thick reinforced concrete is less expensive than compacting it. Would that be okay? I don't care if the wall settles, as long as it settles uniformly. I think it will as the thickness of fill is a constant 5 feet along the wall's length. The wall is 75' long. Also, even though it is loose laid stone, the masons want to stick concrete on the inside of it to stiffen it up. Thanks.
Fill hole in foundation wall after Gas line was removed ctbfalcon Building & Construction 2 05-03-2010 09:16 AM
questions on a rock climbing wall CHEFLETCH86 General DIY Discussions 0 04-28-2010 03:22 PM
How to calculate how much rock fill and asphalt to order? Negativecreep0 Landscaping & Lawn Care 5 04-08-2010 10:08 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-21-2010 12:26 AM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
