Riding Mower Will Not Fire Up - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-15-2015, 05:57 PM   #1
Rewards Points: 294
Riding mower will not fire up
My riding mower will not fire up, it just spins with plenty of battery strength but will not start. How can I fix it?
Mikeron is offline   Reply With Quote
Old 05-15-2015, 06:01 PM   #2
John
JD367's Avatar
Rewards Points: 206
What make/model/engine ?
You can try dribbling a small amount of fuel in the intake,and see if it starts. If it does,check: fuel filter, fuel solenoid,and fuel tank vent.
If it doesn't,check spark plugs for spark.
JD367 is offline   Reply With Quote
Old 05-15-2015, 07:04 PM   #3
Rewards Points: 1,550
If it is a single cylinder engine, 2 critical things can be checked by removing the spark plug. Reconnect the plug wire to the plug and ground the plug to the head and a nice blue spark should be seen across the plug gap.
While the plug is out check compression by holding thumb or finger tightly on plug hole. If it's difficult to hold your finger there compression is good enough to start.
If those are correct the 1/2 or so teaspoon of gas into the intake should fire and start momentarily.
SeniorSitizen is offline   Reply With Quote
Propane Mower Conversion homerb Green Home Improvement 21 03-16-2016 04:42 PM
Concrete Fire Pit Project - Advice polizei11 Concrete, Stone & Masonry 2 11-13-2012 02:34 PM
90's model murray riding mower foxtro Landscaping & Lawn Care 1 06-19-2012 09:52 AM
Riding mower Davejss Automotive Repairs 3 05-31-2012 03:38 PM
Audit your riding mower deck this spring tbeaulieu Landscaping & Lawn Care 1 05-12-2010 10:33 PM
