Riding Mower - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-14-2017, 07:18 AM   #1
Edw
Rewards Points: 38
Riding Mower
Hello Folks. I am hoping someone can help with this problem. My riding mower runs O.K with choke (throttle) in almost full open and almost full closed positions but stalls out when choke (throttle) is in the normal position for operation. Any suggestions are much appreciated. Thanks to all.
Edw is offline   Reply With Quote
Old 07-14-2017, 08:47 AM   #2
Rewards Points: 202
Re: Riding Mower
Some details might help, such as make, model, age, etc., but, as far as I know, most mowers want to be run at or near full throttle when mowing. But, if it's not running properly at the manufacturer's recommended setting, and speaking in very general terms, it sounds like the fuel system is the most likely culprit. Start with a thorough carburetor cleaning, as in remove, disassemble, clean, reassemble, reinstall, and see how that work. Unless the fuel is brand new, I would also drain the tank and replace it with fresh. Try to find non-ethanol fuel for it.
Old 07-14-2017, 10:34 AM   #3
Big Dog
Drachenfire's Avatar
Rewards Points: 3,998
Re: Riding Mower
If you cannot find ethanol free fuel. Try mixing 91+ octane fuel with some Sta-Bil 360 Performance. I recently started running this in my 22-year-old MTD with B&G engine and there is a noticable improvement.
A 10oz bottle at Lowe's is less than $8 and at 1oz per 5 gallons of gas should last a good while (unless you have a lawn the size of a soccer field).
Drachenfire is offline   Reply With Quote
Old 07-14-2017, 03:46 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,344
Re: Riding Mower
Ayuh,... The choke ain't the throttle anymore than the throttle is the choke,....
If ya mean it won't run without the choke On, or partly On, it's plugged up passages in the carb, not allowin' gas flow through it's normal circuits,....
The choke causes a richer condition through other circuits,...
Old 07-28-2017, 07:46 AM   #5
Rewards Points: 2
Re: Riding Mower
I agree with Bondo, the passages are clogged in the carb. I had the same problem with my hedge trimmer, it would run in half choke, but stall out when choke is off. I replaced carb and it runs well now.
G-Man8206 is offline   Reply With Quote
30" Craftsman Riding Mower Model no. 944.601380 ogbill Tractors & Mowers 1 07-31-2016 05:01 PM
Lawn Mower Question - Push or Riding? cbarr81 Tractors & Mowers 15 10-19-2012 09:44 AM
murray riding mower wont start ColbyZ Landscaping & Lawn Care 15 07-08-2012 06:54 PM
Audit your riding mower deck this spring tbeaulieu Landscaping & Lawn Care 1 05-12-2010 10:33 PM
Riding Lawn Mower Washer Willy Landscaping & Lawn Care 2 03-23-2007 12:25 PM
