Ribbon Driveway - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 03-02-2019, 02:43 PM   #1
Rewards Points: 12
ribbon driveway
i have a hard pack road mix driveway. i want to place two 2 ft. wide strips (ribbon). my plan is to roto-till the strip down 4 inches. leave the loose material in the strips, then lay rock chips down and compact it, adding more rock chips as it compacts down. will this make a solid track to drive on? thanks for any info you might have. god bless.
lclc49 is offline   Reply With Quote
Old 03-02-2019, 04:28 PM   #2
retired framer
Rewards Points: 20,348
Re: ribbon driveway
what is hard pack road mix.
Do not use flat bottom gables with scissor trusses.
Old 03-02-2019, 04:40 PM   #3
Rewards Points: 12
Re: ribbon driveway
compacted road mix. the base of my driveway is a hard dirt, the surface has about 1/2 inch to an inch of loose dirt/dust.if i dig down 4 inches the it should be a pretty firm strip.
Old 03-02-2019, 05:08 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,342
Re: ribbon driveway
Ayuh,..... Hard packed road gravel will laugh at a roto-tiller,.....
If yer gonna end up with a gravel 2 strip driveway,.....
I'm wonderin' just what you expect to change by loosenin' the strips,...??....
Yodaman likes this.
Old 03-02-2019, 05:17 PM   #5
retired framer
Re: ribbon driveway
Put down 3" of 3/4 crushed and compact it in with a heavy plate compactor that will firm up the dirt, then put what ever you want on top of that and compact it again.
I have done that with top soil, the driveway still looks good after 30 years.
lclc49 likes this.
Old 03-02-2019, 05:18 PM   #6
Property Mgt/Maint
Rewards Points: 6,526
Re: ribbon driveway
I sure wouldn't want to be a the operator.
And what is a ribbon drive way? Are we talking about the 2 tire track ruts on a dirt drive?
[political signature removed]
Yodaman is offline   Reply With Quote
Old 03-02-2019, 05:20 PM   #7
Rewards Points: 12
Re: ribbon driveway
normally once the strip was loosened, the loose dirt would be removed. leaving a 2 ft. wide 4 inch deep trench. then a base material would be laid down, then the rock chips then it would all be compacted down using a compactor. what want to do is loosen the same area, leave the loose soil as the base, lay the rock chips on top of the loose dirt, compacting this will use the loose dirt unde the rock chips to bind together. i would keep adding the rock chips and compacting it until i got a semi-smooth hard driveable surface.
Old 03-02-2019, 05:29 PM   #8
Property Mgt/Maint
Re: ribbon driveway
Honestly I would not spend my time digging out "ribbons". I would level by raking or grading, then have a load of stone brought in telling the driver to tail-gate spread it the length of the drive way.
Bondo and lclc49 like this.
The Following User Says Thank You to Yodaman For This Useful Post:
lclc49 (03-02-2019)
Old 03-02-2019, 05:31 PM   #9
retired framer
Re: ribbon driveway
Opps. ignore this.
Old 03-02-2019, 05:32 PM   #10
Rewards Points: 12
Re: ribbon driveway
i am using the loosened material i end up with from tilling the two strips as my loose base and binding material for the rock chips?
Old 03-02-2019, 05:39 PM   #11
retired framer
Re: ribbon driveway
Fill it with bigger crushed.
The Following User Says Thank You to Nealtw For This Useful Post:
lclc49 (03-02-2019)
Old 03-02-2019, 05:43 PM   #12
Bondo's Avatar
Re: ribbon driveway
Ayuh,.... Insteada stone chips aka: washed stone,.....
Use crusher-run 3/4"- minus,....
It's self compactin', because the fines are still in the mix,.....
The Following User Says Thank You to Bondo For This Useful Post:
lclc49 (03-02-2019)
Old 03-02-2019, 05:45 PM   #13
Rewards Points: 12
Re: ribbon driveway
i was looking at using "Brick Chips" crushed up bricks, 3/4 inch. pack the brick chips into the loose dirt, compact it, add more chips, compact it. issue is will the brick chps hold up when compacted or do you think the compactor will just turn them to dust?
Old 03-02-2019, 05:50 PM   #14
retired framer
Re: ribbon driveway
Probably, all I know is a gravel guy told me what to do instead of hauling the dirt out and it worked.
lclc49 (03-02-2019)
Old 03-02-2019, 05:58 PM   #15
Rewards Points: 12
Re: ribbon driveway
i have considered doing that. because there is a slight rise in my driveway i wanted a harder surface that would be easier to drive up without spitting out any chips. pluse the look of the two ribbons with grass outlining the tire strips will look much better. that is why i am looking at colored rock chips.....
Run-Off Issues from Driveway to House Logan176 Building & Construction 9 08-10-2016 11:54 AM
How to repair a cracked driveway or walkway [email protected] How To Guides 8 06-15-2015 03:59 AM
Ribbon driveway? benjamincall Landscaping & Lawn Care 13 07-21-2014 05:37 PM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
