Reusing Pavers And Base Material - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-20-2017, 09:45 AM   #1
Rewards Points: 48
Reusing pavers and base material
I have a small 15 x 15 paver patio about 10 years old sinking in several places. I want to pull up and reset the pavers in a better base. I had a concrete border/curb installed around the perimeter levelled and sloped ready to be my guide for the paver reinstallation.
The existing pavers were laid on what appears to be about 4 inches of bedding sand. Trying to reuse what I can so my question is should I
A)remove all of that sand and replace with gravel, compacted and then reuse bedding sand for top 1"?
B)Leave some of the sand and mix with gravel and compact and then beddding sand on top for levelling
Trying to avoid having to haul away material that can be re used.
Since I am trying to get the pavers to be level with the new border/curb after compaction with a mechanical vibrator, how much higher should I set them? Ie will plate compactor push them down an 1/8th inch or more?
kal72 is offline   Reply With Quote
Old 05-20-2017, 11:55 AM   #2
JUSTA MEMBER
Rewards Points: 4,080
Re: Reusing pavers and base material
Option A, is the way I do it.
Too much sand won't compact, and will be loose enough that the pavers eventually sink in in places.
Compacted well the gravel supports the sand better, and the final compaction of pavers and all should be done with a carpet on the plate to keep from breaking any pavers, and should not be forceful enough to drive them deeper.
So be gentle on the final compaction.
ED
de-nagorg is offline   Reply With Quote
Old 05-20-2017, 12:17 PM   #3
jlhaslip's Avatar
Rewards Points: 708
Whether you use method A or B, I have found that the base material can be compacted quite nicely by using water via a sprinkler a couple of times a day over several days to reach an acceptable degree of compaction. Sand or Gravel doesn't matter.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 05-20-2017, 06:55 PM   #4
Rewards Points: 1,042
Mason sand or bank sand can be compacted with water as it's a very fine sand, the bedding sand should be #2 torpedo or the same sand thats used for a concrete mix.
Canarywood1 is offline   Reply With Quote
Question about determining how much base material is needed under driveway CountryB Concrete, Stone & Masonry 18 09-20-2016 12:17 PM
Travertine pavers driveway in cold climate Leopro Concrete, Stone & Masonry 7 01-04-2013 11:06 PM
Patio Base material - Pavers Kevinnkingwood Landscaping & Lawn Care 2 06-23-2011 03:17 PM
landscaping backyard with Pavers - needs concrete base? sundar Landscaping & Lawn Care 7 10-09-2008 07:28 PM
edging material for base rock and patio pavers la15ota Landscaping & Lawn Care 1 07-04-2008 10:01 AM
