Retaining Wall With Timbers, Deadmen Vs Retaining Posts? - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 09-09-2015, 08:10 PM   #1
Rewards Points: 4
Retaining wall with Timbers, deadmen vs retaining posts?
Im building 2 retaining walls on a 5' slope approx 30" high for the lower one and 25" for the upper out of 6x6" juniper timbers.
The upper to extend the yard on the wasted hillside and the lower for a herb garden similar to the walls in the picture.
My question is:
Are Dead-men better like they used in the picture or
Are retaining posts just as good.
It would be easier to get a 2 man auger than to dig for the dead-men in my case.
ps there is no big sloping hillside behind the walls, just a small flat grass yard
Also is 3/4 minus ok rock to use under the 1st timber and behind timbers for drainage, i have a bunch from a paver walkway left over. I plan on putting a pipe/french drain behind it with filter fabric.
Thanks for any advice.
jeffbeck27 is offline   Reply With Quote
Old 09-10-2015, 02:51 PM   #2
Rewards Points: 4
ops forgot pic
Retaining wall with Timbers, deadmen vs retaining posts?-screen-shot-2015-09-09-6.02.52-pm.jpg
Old 09-10-2015, 03:39 PM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,340
Ayuh,... Deadman/ tie-backs are No doubt stronger,.....
but it's Yer choice,....
Bondo is online now   Reply With Quote
Joining thin wall abs pipe to standard abs pipe Homerepairguy Plumbing 3 03-01-2015 11:39 PM
Help retaining Wall 6x6 Timbers, out of plumb carneyxii Landscaping & Lawn Care 19 04-25-2013 11:55 AM
Retaining wall work-- what approach? emcelvaney Landscaping & Lawn Care 2 09-24-2012 07:49 PM
Retaining wall problem FMS Landscaping & Lawn Care 6 07-04-2011 06:42 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
