Retaining Wall For Shed - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 05-03-2018, 01:29 PM   #1
Rewards Points: 2
Retaining wall for shed
I'm planning on putting a 14x20 shed/garage at the back corner of our property about 6 feet up from the water. It's obviously way out of level but it's really my only option. I got a bid to do a retaining wall using nice blocks and filling it with gravel. It was $9,000 which is not doable. What other options do I have? Would buiding it using treated wood be a drastic price difference? The shed is on 6x6 runners. Would concrete piers be an option? Thanks for any replies.
Luke3304 is offline   Reply With Quote
Old 05-03-2018, 03:03 PM   #2
Rewards Points: 1,864
Re: Retaining wall for shed
Clarification of the building use, has to be determined before the supports can be. A shed/garage combo ? Will the garage have a gravel floor ? Concrete floor ? Have a sketch with dimensions to show individual building sizes /wall layout ?
Gregsoldtruck79 is offline   Reply With Quote
Old 05-03-2018, 04:09 PM   #3
Rewards Points: 2
It's just for my rider and some miscellaneous stuff. It has a 3/4 plywood floor.
Old 05-03-2018, 05:40 PM   #4
Rewards Points: 17,912
No location in your profile, is this in a flood zone?
No way would I be spending that kind of money on a retain wall!
If I had to do it I'd be laying it out and installing poured piers to set soild concrete blocks on to act as piers.
Old 05-03-2018, 06:21 PM   #5
Rewards Points: 2
Updated the location. No not in a flood location.
Old 05-04-2018, 10:14 PM   #6
Msradell's Avatar
Rewards Points: 818
Why not just set the shed upon pillars? Certainly cheaper and less expensive than retaining wall.
Written using Dragon Naturally Speaking
Msradell is offline   Reply With Quote
Old 05-04-2018, 10:28 PM   #7
Rewards Points: 1,251
6 feet from that water? I'd be concerned about having a solid footing.
What you could do is a stepped footing with block on top to raise it high enough out of the ground to then build side and back walls.
Or you can do like they did here with a ramp for whatever you'll be driving into it.
Build a shed on a slope
KHouse75 is offline   Reply With Quote
Replacing retaining wall in front of old wall - options? dc300m01 Landscaping & Lawn Care 2 07-04-2016 09:43 PM
Replace Collapsed 4' Retaining Wall With Dirt Slope? gunner666 General DIY Discussions 4 08-07-2014 10:09 PM
Please help with retaining wall / patio issue that has arisen. coderguy Landscaping & Lawn Care 3 05-26-2012 04:45 PM
my concrete retaining wall has a major crack where the wall has now shifted DanDaMan Building & Construction 1 04-02-2011 11:34 AM
Retaining Wall Demolition --HOW? tdrumm Landscaping & Lawn Care 12 03-20-2011 02:32 PM
