Retaining Wall Options - Specifically, Brands - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 04-17-2017, 10:52 PM   #1
Rewards Points: 102
Retaining wall options - specifically, brands
My yard has a 63" elevation change from my property line to the back of the house. I also receive the runoff from three properties behind me.
Fortunately, I do not have a water problem with my house, however, my back yard is often wet and due to the elevation pretty much useless.
There is a pronounced ridge that would be ideal for a retaining wall.
My goals with the wall are:
1. alter the slope of the upper section of the yard to slow down the speed of runoff.
2. create a place to capture water and direct it into 4" or 6" pipe to guide it around to the front of the house.
3. change the grade directly behind the house to create a flat space to pour a patio.
I am working with a concrete company - they poured my driveway a couple years ago - to pour the patio. I cannot afford to hire a landscape company to install a retaining wall.
My plan is to have the concrete team cut in the area for my wall, dig out the trench for stone and sand and compact it with their equipment. This just leaves me to install the block, drain pipes, stone, and move dirt back in to place.
Last week I spent a couple hours measuring elevation changes with a rotary laser and created a surface map of my yard.
I hope to follow the ridge by cutting into it and half way following the curve. I imagine the wall will peak at 36-40" in one section for about 8-10'.
What this post is really about is retaining wall block options. I've seen Versalock, but i cannot imagine they are the only game in town. What other companies or systems would be suitable for this task?
The patio is going to be between 20-24' wide and 14-16' deep. The back of the addition servicing the patio is 34' wide - for reference.
The images below:
- each line is 3" in elevation change.
- the house section is 24' wide to give a sense of scale.
iH8usrnames is offline   Reply With Quote
Old 04-18-2017, 06:29 AM   #2
Civil Engineer
Rewards Points: 5,246
Re: Retaining wall options - specifically, brands
There are many manufacturers of segmental concrete block (the generic name for interlocking concrete block). Some are local, some national. In my area, Superior Concrete makes blocks, Allan Block is widely sold. If you go to a concrete supplier they will likely have several varieties available. The most important thing is to get the design manual from the block manufacturer, read it, and make sure you follow it. The manual should explain how to prepare the base, install the drainage, what type of backfill is needed, and should explain how to install soil reinforcing (if needed).
Old 04-20-2017, 11:13 AM   #3
Rewards Points: 297
The low cost and high weight of things like concrete pavers and retaining wall units means that they aren't typically shipped all over the country. You likely have one or two brands in your area that have much better availability just because they are produced within a reasonable distance.
Do a search for "segmented retaining wall companies" and you'll find quite a few. Anchor, Allen Block, Everlock, Belgard, etc, etc, etc.
red92s is offline   Reply With Quote
Old 04-20-2017, 12:06 PM   #4
Engineer
MikeFL's Avatar
Rewards Points: 182
A picture of the yard and the house would help. To build the wall you need to start at the bottom. Your options for the bottom (and the entire wall) are a function of the soils, terrain and loading.
Michael Gookin, President
GPS LightLock Astronomical Timers
www.GPSLightLock.com
(239) 848-6675
MikeFL is offline   Reply With Quote
Retaining wall against brick+cement block foundation. Waterproofing options? homeimproverjoe Landscaping & Lawn Care 3 03-20-2017 02:47 PM
Replacing retaining wall in front of old wall - options? dc300m01 Landscaping & Lawn Care 2 07-04-2016 09:43 PM
Retaining wall vs grading slope pros / cons advice please afrig Landscaping & Lawn Care 11 03-09-2016 03:38 PM
Cheapest Retaining wall diy4life Landscaping & Lawn Care 15 03-21-2012 10:18 AM
6X6 Timber Retaining Wall Additions Tom5151 Landscaping & Lawn Care 2 02-22-2012 10:46 AM
