Retaining Wall Or Edging - Landscaping & Lawn Care - DIY Chatroom Home Improvement Forum
Old 07-05-2015, 09:58 AM   #1
Rewards Points: 58
Retaining wall or edging
I am debating whether to build a small (6" height) retaining wall around my side and front landscape or to just use edgers instead. I have attached a pic. If I build a retaining wall I would have to build up the dirt, is that going to cause drainage issues? Anyone have any suggestions or opinions on what I should do here?
Thanks in advance
saxsquad29 is offline   Reply With Quote
Old 07-05-2015, 11:27 AM   #2
Rewards Points: 7,003
It might. Is that a basement window under the bay?
It looks like you have good drainage now. I would be inclined to do edging only and keep the grade away from the undisturbed.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 07-05-2015, 11:50 AM   #3
Rewards Points: 58
Egress window under the bay window. If I used retaining wall blocks I would add more dirt next to the foundation to allow for slope. Window wells would be added on the far basement window as well as another retaining wall around the egress to allow for more dirt.
Old 07-06-2015, 07:34 AM   #4
Rewards Points: 58
I really like the look of retaining walls. As long as I add enough dirt for correct slope there should not be a problem with drainage, right? Plus the wall will be less than 6 inches in height above grade.
Can you build a retaining wall in front of an old retaining wall? bb33 Concrete, Stone & Masonry 10 07-29-2014 01:21 PM
sleeper retaining wall eddytheflow Landscaping & Lawn Care 0 07-18-2012 08:01 AM
Please help with retaining wall / patio issue that has arisen. coderguy Landscaping & Lawn Care 3 05-26-2012 04:45 PM
my concrete retaining wall has a major crack where the wall has now shifted DanDaMan Building & Construction 1 04-02-2011 11:34 AM
Retaining Wall Demolition --HOW? tdrumm Landscaping & Lawn Care 12 03-20-2011 02:32 PM
