Retaining Wall - Landscaping & Lawn Care - Page 3 - DIY Chatroom Home Improvement Forum
Like Tree12Likes
Old 01-04-2019, 08:09 AM   #31
Rewards Points: 7,492
Re: Retaining Wall
I rather like the looks of the walls that shumakerscott put into his German house rebuild. (Pages 166-168 and 176-178)
SPS-1 is online now   Reply With Quote
Old 01-04-2019, 09:05 AM   #32
Rewards Points: 48
Re: Retaining Wall
Originally Posted by de-nagorg View Post
A framing nail gun, won't have any impact on the posts, if nailing.
ED
I do have a small pancake compressor that's 150 PSI but only trim tools for it. I wonder if I can use a framing nailer with it. The ones I'm looking at say minimum 70 PSI. I'm going to stop after work and pick up more lumber for the weekend. I'll have to check them out.
clancaster23 is offline   Reply With Quote
Old 01-04-2019, 09:08 AM   #33
JUSTA MEMBER
Rewards Points: 3,990
Re: Retaining Wall
Yep, mine works fine on a pancake compressor, remember to regulate the pressure, to less than MAX, you don't want to break it.
ED
de-nagorg is online now   Reply With Quote
Old 03-23-2019, 04:37 PM   #34
Rewards Points: 48
Re: Retaining Wall
So I got the wall up and part way through spreading gravel and now I'm thinking maybe I shouldn't have that much gravel right up against the wall. I'm afraid of the weight of the gravel after it's down pushing the posts even though they are in deep. I'm not sure what to do now though. Would just plain dirt fill be easier on the wall until I get about 6 inches from the top then I can top it off with a good layer of gravel? Two pics to show what I got. Using 2"x10"s so I got about 20" to fill and I'm thinking it shouldn't be solid gravel.
https://drive.google.com/open?id=1tR...2gm0bxlCZgvt69
https://drive.google.com/open?id=1A9...yNmihLjzu9-LUq
Old 03-23-2019, 10:06 PM   #35
JUSTA MEMBER
Re: Retaining Wall
The gravel will be less weight than solid dirt, due to the small pockets left between them, even if vibrated packed.
So use either one, and if using a power tamper, do be gentle around the edges.
ED
Old 04-03-2019, 03:31 PM   #36
Rewards Points: 578
Re: Retaining Wall
Cheapest long lasting retaining wall is one constructed using railroad ties. Only drawback is their weight of over 100 lbs per tie.
http://www.akrailroad.com/products/landscape-ties
An alternative solution for a retaining wall is to buy wire gabion cages which are then filled with rocks. Very different look at very stable but I would want to have a tractor access at the very least and not be hauling the rocks in a wheelbarrow (unless I rented a power wheelbarrow).
https://www.gabion1.com/square-gabions/
Calson is offline   Reply With Quote
Replace Collapsed 4' Retaining Wall With Dirt Slope? gunner666 General DIY Discussions 4 08-07-2014 10:09 PM
Please help with retaining wall / patio issue that has arisen. coderguy Landscaping & Lawn Care 3 05-26-2012 04:45 PM
my concrete retaining wall has a major crack where the wall has now shifted DanDaMan Building & Construction 1 04-02-2011 11:34 AM
Retaining Wall Demolition --HOW? tdrumm Landscaping & Lawn Care 12 03-20-2011 02:32 PM
Adding drainage to existing retaining wall? pcballgame Landscaping & Lawn Care 5 04-14-2009 03:29 PM
